Re: Best way to measure piston depth in the hole?
[Re: RapidRobert]
#322298
05/19/09 07:38 AM
05/19/09 07:38 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you could pick up a cheap dial indicator and magnetic base. lay a straight edge accross the cylinder, zero the gauge, then remove the straight edge (being careful not to move the indicator) and bring the piston to TDC to take a reading. use your calipers to measure the thickness of the straight edge and subtract that from the total indicated reading on the dial indicator. should get you close enough ![](/ubbthreads/images/graemlins/beer.gif)
**Photobucket sucks**
[Re: polkat]
#322301
05/19/09 11:35 PM
05/19/09 11:35 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Okay, after trying several of the methods mentioned, I seem to get a consistant .115" in all cylinders. That sound about right? Thanks!
you're working on a 400 right?
That is about right.
I think mine varied from .100 to .115
