Moparts Vendors with Victor Jr. Hemi heads in stock? #3222717
03/25/24 04:11 PM
03/25/24 04:11 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
Summit just sent me an email saying the heads I have on order will be delayed at least 1 month.
Any Moparts sponsors have them available? With roller springs or valves only is fine.
Victor Jr. CNC fully assembled: 61175
or
Victor Jr. CNC with valves: 61189
I saw some ebay listings, but if possible would prefer to buy from a company that supports the forum.
Craig
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: Craig J] #3222836
03/26/24 07:31 AM
03/26/24 07:31 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Things are starting to become like Covid times with Automotive parts.. If you also need crank rods or pistons I would be ordering them now because I have been told the wait could be into the fall for some parts. Experienced workers are hard to fin dnot a days so manufacting has slowed, and some times the company has stopped offering some services suh as a source to rebuild some roller lifters.Eddy Jr. Heads you might want to buy any that are available now.or email/phone to see when they could be built. I got luck for a friend and just happen to be at a warehouse that had 61175s in stock and I picked them up for him and have not studied what they are but sounds like they are the good ones but he intends to change Springs and Retainers. Not sure what is even on them for springs and retainers. Still gathering parts for this build and likely will not get what he needs for 6 month or more. Another reason why buying off FHO or RBE might be more money but they seem to control invertory much better.
1971 HEMI E BODY REGISTRY
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: Craig J] #3222838
03/26/24 07:51 AM
03/26/24 07:51 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
There has been a recent issue with the Victor Jr. Hemi heads that I suspect is the reason for no availability - the final machine work on the chambers apparently was off slightly and the chambers on some heads were not lining up with the bores - creating a slight interference issue. I have had a set on order for a while and its been a couple of months - but if you do find a set - have them checked for bore spacing. They are a great design of a head that was somewhat based off the original canfield head - which is now the INDY HiPo heads.
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: DoubleD] #3222844
03/26/24 09:18 AM
03/26/24 09:18 AM
Craig J Offline OP
Craig J  Offline OP
Thank you very much for this information. I would like to use the HiPo head, but I am not sure about using the raised exhaust port with iron manifolds in a Cuda with stock bellhousing, power steering, stock k member... The Eddie heads are listed as having stock exhaust port position.
Craig
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: Craig J] #3222846
03/26/24 09:24 AM
03/26/24 09:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It's not exactly the stock exhaust position but I've never heard of anyone having a problem. The Victor Jr's are what you want.
2011 Drag Pak Challenger
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: Craig J] #3222890
03/26/24 01:11 PM
03/26/24 01:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would check with Todd at Marsh Performance to help you round up your parts.
He is a straight shooter with good prices.
http://www.mopartsracing.com/
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: 340Cuda] #3222895
03/26/24 01:28 PM
03/26/24 01:28 PM
NY
B1duster Offline
B1duster  Offline
NY
There is a pair on Facebook marketplace, Allentown PA
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: B1duster] #3222905
03/26/24 01:53 PM
03/26/24 01:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've always heard Edelbrock had close to the lowest profit margin in the industry, which didn't give much incentive to keep them in stock
even for higher volume sellers.
But that was decades ago, maybe it's all changed now.
Rich H.
Esse Quam Videri
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: ZIPPY] #3222944
03/26/24 05:33 PM
03/26/24 05:33 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Just don't buy them bare because that means they don't have a valve job and unless you have a good man for that it can get ugly.
Re: Moparts Vendors with Victor Jr. Hemi heads in stock? [Re: DoubleD] #3223719
03/30/24 02:04 PM
03/30/24 02:04 PM
Craig J Offline OP
Craig J  Offline OP
Thank you for this info, I will be checking for it soon. The heads I got were 'open box' which is a bit disappointing, and maybe were used in a partial mock up before... Do you happen to know the date range that might have had the problem?
Craig
