New cast iron Hemi block #3222699
03/25/24 01:52 PM
03/25/24 01:52 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I’m tired of messing with the old block, who sells a new one that I can get within a reasonable time? Standard 4.25 bore to start with.
Re: New cast iron Hemi block [Re: cudaman1969] #3222724
03/25/24 05:12 PM
03/25/24 05:12 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Callies iron blocks just google them and see what bores they have. FHO has used a few for customers that wanted an iron block. I have see a few for sale on mopar sites and ebay just take a look around.
1971 HEMI E BODY REGISTRY
Re: New cast iron Hemi block [Re: cudaman1969] #3222783
03/25/24 09:21 PM
03/25/24 09:21 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Rich H.
Esse Quam Videri
Re: New cast iron Hemi block [Re: cudaman1969] #3222813
03/25/24 10:52 PM
03/25/24 10:52 PM
AndyF Offline
AndyF  Offline
Get a stack of hundreds out of your wallet and start calling around. Several people claim to make them, but actual examples can be hard to find.
Re: New cast iron Hemi block [Re: AndyF] #3222814
03/25/24 11:27 PM
03/25/24 11:27 PM
fredericksburg,va
fredericksburg,va
I found different prices from $3200 to $6000, I’ll call around tomorrow to see availability. Don’t know how many different blocks are being produced now.
Re: New cast iron Hemi block [Re: cudaman1969] #3222822
03/26/24 02:03 AM
03/26/24 02:03 AM
NY
B1duster Offline
B1duster  Offline
NY
I don’t think you’ll find to many for less than 6k
Re: New cast iron Hemi block [Re: B1duster] #3222833
03/26/24 06:47 AM
03/26/24 06:47 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I understand that a new Hemi block is a large purchase. Why would you spend $5500-6000 for an iron block when you can get an aluminum one for $1500 more? Repairable and 150 lbs lighter.
Re: New cast iron Hemi block [Re: fbs63] #3222848
03/26/24 09:51 AM
03/26/24 09:51 AM
fredericksburg,va
fredericksburg,va
Because it will be street only and I don’t want a block that ‘moves’ around in the cold to hot cycle and please don’t say aluminum won’t grow. Besides it’ll look dumb with cast iron heads.
Re: New cast iron Hemi block [Re: cudaman1969] #3222854
03/26/24 10:35 AM
03/26/24 10:35 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Surely one of the vendors will have a Callies block. 4.25 bore might be harder though. I assume they mainly sell 4.500. But I don't know that.
2011 Drag Pak Challenger
Re: New cast iron Hemi block [Re: rickseeman] #3222869
03/26/24 11:53 AM
03/26/24 11:53 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Paint bock orange....Absolutely NO reason to not run an aluminum block on the street. good luck finding a 4.25" bore, only one who MIGHT be close is Jason Lines stuff but it comes with other things you likely wont need for a street car like a 60MM cam.
Re: New cast iron Hemi block [Re: Al_Alguire] #3222923
03/26/24 03:29 PM
03/26/24 03:29 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I thought Kent Ritter took over that stuff? Here is a link, jump to 18:00
https://youtu.be/68w2I-m69TE
Re: New cast iron Hemi block [Re: rickseeman] #3224708
04/03/24 11:43 AM
04/03/24 11:43 AM
WA
Air Grabbler Offline
WA
Refer back to Zippy’s post.
Re: New cast iron Hemi block [Re: cudaman1969] #3224813
04/03/24 05:37 PM
04/03/24 05:37 PM
gregsdart Offline
gregsdart  Offline
Paint and headers hide a lot of sin😁
Besides, aluminum requires some extra care, bur it isn't unworkable. Run a bit tighter main bearing clearance, expect .008 to .010 deck hieght growth, and i would go aluminum heads as well if you can budget for it. Now you have a kller hemroid, and about 150 lbs less up front!
Re: New cast iron Hemi block [Re: cudaman1969] #3224817
04/03/24 05:54 PM
04/03/24 05:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have a slightly used one here I bought from Callies, some time ago....I might let it go, but its not free....I actually have two, one is a complete engine that could go for the right price as well.
Re: New cast iron Hemi block [Re: Dragula] #3225090
04/04/24 07:46 PM
04/04/24 07:46 PM
Berlin NJ
scottk Offline
scottk  Offline
Berlin NJ
I would be interested if cudman passes.
Re: New cast iron Hemi block [Re: Al_Alguire] #3225321
04/05/24 11:33 PM
04/05/24 11:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Can you tell us how much street driving you did with your aluminum hemi block? And which block was it?
Re: New cast iron Hemi block [Re: Al_Alguire] #3225371
04/06/24 09:56 AM
04/06/24 09:56 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Painted mine orange because I wanted that kind of stock look since Istreet drive it , but a race car at the same time. Also running a 60mm as well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New cast iron Hemi block [Re: 6PKRTSE] #3225434
04/06/24 02:31 PM
04/06/24 02:31 PM
I'm wondering if painting the aluminum blocks and or heads will affect how cooling will be held into the part and slow down cooling compared to no paint work shruggy
Re: New cast iron Hemi block [Re: cudaman1969] #3226163
04/09/24 10:26 PM
04/09/24 10:26 PM
NY
B1duster Offline
B1duster  Offline
NY
Someone just listed a new in the box Callie's 4.25 block on Facebook.
It’s in Dawsonville Ga. - $6500
