Siding guys? Nail gun options?
#3222727
03/25/24 05:35 PM
03/25/24 05:35 PM
Posts: 5,854 ohio
ruderunner
ohio
Anyone here do vinyl siding on a regular basis? I'm planning on siding the house and barn this summer and could use recommendations on a nail gun.
Not looking for anything professional grade but I figured purchasing vs rental would give me flexibility on work time.
Also, who has nails for guns? All my local places have single nails in boxes. Nope nope nope. I'm not putting up 37 square of siding with a hammer.
Angry white pureblood male
Re: Siding guys? Nail gun options?
[Re: Stanton]
#3222758
03/25/24 07:03 PM
03/25/24 07:03 PM
Posts: 5,854 ohio
ruderunner
ohio
Siding is supposed to be hung loose so it can expand and contract with the temperature - that's why the nail holes are 1" long slots. You sure as hell don't want to be hanging it with a nail gun. Not my first rodeo with siding. I'm aware it should be loose. But this is a big job for one guy and I figured pros would have a tool for it or know a trick.
[Re: IROC78]
#3222790
03/25/24 09:49 PM
03/25/24 09:49 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I like to use what is called a wafer head screw. But then again I'm far from a pro. I like those too BUT ... he's trying to get the job done fast and you're suggesting screws !!!
[Re: Stanton]
#3222828
03/26/24 05:52 AM
03/26/24 05:52 AM
Posts: 5,854 ohio
ruderunner
ohio
I like to use what is called a wafer head screw. But then again I'm far from a pro. I like those too BUT ... he's trying to get the job done fast and you're suggesting screws !!! Screws could work but they should be aluminum. Steel can rust and leave streaks on the siding. Speed is nice but I'm trying to save 50ooo hammer swings.
[Re: 67vertman]
#3222829
03/26/24 05:54 AM
03/26/24 05:54 AM
Posts: 5,854 ohio
ruderunner
ohio
Ah ha! They do exist. Now to find a preferably local source and nails to go with. Thanks.
[Re: ruderunner]
#3222843
03/26/24 09:14 AM
03/26/24 09:14 AM
Posts: 4,771 Star Idaho
67vertman
Star Idaho
Ah ha! They do exist. Now to find a preferably local source and nails to go with. Thanks. Depending on the length you need....https://www.fastenal.com/product/Fasteners/Nails/Pneumatic%2520Nails?query=siding+nails&productFamilyId=39071&categoryId=600132
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3222957
03/26/24 06:17 PM
03/26/24 06:17 PM
Posts: 5,854 ohio
ruderunner
ohio
My local places aren't that great. A couple recommended roofing guns and nails.
Um, no.
As for nail length, I'm figuring 1-1.25 just going over T111 .
[Re: ruderunner]
#3223896
03/31/24 08:17 AM
03/31/24 08:17 AM
Posts: 5,854 ohio
ruderunner
ohio
So I've been looking at the Bostich nailer and have a question.
Some information indicates the gun has a stop to prevent driving nails too tight but other reports indicate the need to play with air pressure.
What's your experience Vertman?
And of course it's mail order only around here so seeing it up close and personal isn't happening.
[Re: ruderunner]
#3223984
03/31/24 12:48 PM
03/31/24 12:48 PM
67vertman
Star Idaho
And of course it's mail order only around here so seeing it up close and personal isn't happening. Yeah mail order is a bummer. I use both, depth setting and air pressure as it seems to result in repeatable results. I have a adjustable pressure regulator at the air intake of the nailer. Nail length and the type of wood, age of the wood all play into how far the nails "sink" in. Just a little practice and playing with the air pressure results in pretty constant nail penetration. For siding 60 to 80 PSI at the gun and 150 out of the compressor. Roofing with shorter nails 40 to 50 PSI. , Practice with a piece of similar wood on the sheeting on you buildings and a your new siding.
[Re: 67vertman]
#3224235
04/01/24 12:43 PM
04/01/24 12:43 PM
Posts: 5,854 ohio
ruderunner
ohio
Yeah, I've got a small inline regulator that I use for my stapler.
So the gun does have a depth setting and basically fine tune it with air?
[Re: ruderunner]
#3224295
04/01/24 02:54 PM
04/01/24 02:54 PM
67vertman
Star Idaho
So the gun does have a depth setting and basically fine tune it with air? Correct!
