Sparton Horn Adjustment Tool #3222440
03/23/24 11:25 PM
03/23/24 11:25 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Does anyone know where to get the tool to adjust a Sparton horn? Can't find anything on the internet and the FSM is of no help.
Re: Sparton Horn Adjustment Tool [Re: 6PakBee] #3222447
03/23/24 11:46 PM
03/23/24 11:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
????????? https://www.brattons.com/PRO-PACK-SPARTON-HORN-REBUILD-KIT/productinfo/19777/
I think these Sparton horn parts are for much older horns than what you might be looking for but maybe this shop knows where to find what you are looking for and need?
Also this https://www.snydersantiqueauto.com/subgrouping.htm?cat=41718
Re: Sparton Horn Adjustment Tool [Re: 6PakBee] #3222449
03/23/24 11:59 PM
03/23/24 11:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Model and Year for Sparton horn?
Re: Sparton Horn Adjustment Tool [Re: A12] #3222471
03/24/24 08:56 AM
03/24/24 08:56 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Have no idea what model. The version used on the '69 B-bodies.
I found numerous sites like the ones you found that sells parts for the Sparton ah-ooga horn, but that is not the case here.
Re: Sparton Horn Adjustment Tool [Re: 6PakBee] #3222596
03/24/24 08:23 PM
03/24/24 08:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Watching as I've looked for this myself in the past popcorn
Re: Sparton Horn Adjustment Tool [Re: TJP] #3226469
04/11/24 12:09 PM
04/11/24 12:09 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Re: Sparton Horn Adjustment Tool [Re: EV2RTSE] #3226694
04/12/24 10:27 AM
04/12/24 10:27 AM
Alberta
rustbuckett68 Offline
Alberta
Just played with a sparton, 68 ish, and torx, hex, 8 point, 12 point sockets wouldn't fit. I counted seven nubs, not six, not eight.
Ended up using needle nose vice grips, sorta worked.
