Sparton Horn Adjustment Tool
#3222440
03/23/24 11:25 PM
03/23/24 11:25 PM
Posts: 10,750 North Dakota
6PakBee
North Dakota
Does anyone know where to get the tool to adjust a Sparton horn? Can't find anything on the internet and the FSM is of no help.
Re: Sparton Horn Adjustment Tool
[Re: A12]
#3222471
03/24/24 08:56 AM
03/24/24 08:56 AM
6PakBee
North Dakota
Model and Year for Sparton horn? Have no idea what model. The version used on the '69 B-bodies. I found numerous sites like the ones you found that sells parts for the Sparton ah-ooga horn, but that is not the case here.
[Re: rustbuckett68]
#3235416
05/28/24 09:29 PM
05/28/24 09:29 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I just found this thread and have a similar or the same question - does the tiny knob on the horn body do anything useful if the horn stops working?
My '65 Sparton Lo horn just stopped working. I apply 12V battery power to it and it just 'clicks' a little.. it seems to draw a high amount of amps..
Does that mean the horn is toast? .. I figure it's not rebuildable, it's all riveted.
.. or does the little adjuster "knob" do anything to help bring the horn back to working condition? See photo..
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#3235466
05/29/24 09:40 AM
05/29/24 09:40 AM
Posts: 1,030 NJ
EV2RTSE
NJ
Agree sometimes just turning the adjuster back & forth cleans the contact enough to get the horn working again. If that doesn't work, following these instructions might be worth a try before looking for a replacement. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/566967/prestolite-horn-repair-101.html I've been able to bring back quite a few non-working Prestolite horns that way. Spartons I believe are nearly identical. Soaking everything in Evaporust worked well. I suppose sometimes the coils burn out and then there's not much that can be done but many times it's just a matter of internal corrosion causing the problem.
[Re: EV2RTSE]
#3235561
05/29/24 09:34 PM
05/29/24 09:34 PM
67SATisfaction
Albany, NY
Thanks, Yes, some rust came out of it after I whacked it. Thanks for that link, good stuff.
OK - When I test the inoperative horn out of the car, with 12V car-battery power directly to the terminal, and then ground the body to the Negative battery terminal, I get a large spark, and no sound. It's seems short circuited but the fuse never blew. I'll check for Ohms and continuity across the terminal to horn-body.. That could be a sign that the coil is fried - short circuited.. right? An operating horn draws quite a few amps doesn't it? I don't know how or if the amp draw relates to Ohms.. I'll ask my High School student..
After that I'll whack it some more and try that adjuster knob, then drill out the rivets and open it up cuz that won't make it any worse.. - Art
#3235568
05/29/24 10:11 PM
05/29/24 10:11 PM
67SATisfaction
Albany, NY
Update:
I whacked the horn a few more times, and I got that tiny knob thing to turn, so I carefully worked it back-n-forth a few minutes but put it back in its original position. Put power to the horn and it worked! ... intermittently.. along with plenty of sparks whenever I grounded it to the Negative terminal.
So, I'll drill out the flared posts and open it up for cleaning.
More tomorrow.. - Art
[Re: stumpy]
#3235602
05/30/24 08:45 AM
05/30/24 08:45 AM
67SATisfaction
Albany, NY
Thank you! I was concerned it might be shorted out.
[Re: 6PakBee]
#3235731
05/30/24 08:45 PM
05/30/24 08:45 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Does anyone know where to get the tool to adjust a Sparton horn? Can't find anything on the internet and the FSM is of no help. It would be a fun project to make some......... Not all that complicated.
[Re: markz528]
#3235743
05/30/24 09:28 PM
05/30/24 09:28 PM
6PakBee
North Dakota
Does anyone know where to get the tool to adjust a Sparton horn? Can't find anything on the internet and the FSM is of no help. It would be a fun project to make some......... Not all that complicated. Well then, step up to the plate. I'll be your first customer!
[Re: 6PakBee]
#3235782
05/31/24 12:19 AM
05/31/24 12:19 AM
markz528
Morrow, OH
Well then, step up to the plate. I'll be your first customer! Anyone else need one while I'm at it? I will make a few more in the morning............
[Re: stumpy]
#3235826
05/31/24 09:31 AM
05/31/24 09:31 AM
6PakBee
North Dakota
Have you ever tried an allen socket? It's a seven point hex of some sort. So no, a conventional hex, Torx, or spline won't work.
