finally built some drive on ramps........... #3222332
03/23/24 12:00 PM
03/23/24 12:00 PM
moparx Offline OP
moparx  Offline OP
i can now squeeze my fat gut under the car with ease. [i should have raised the roof in my shop when i replaced it way back in 1996, so i could have installed a lift]
they are 16 1/2" tall, and the ramps are 4 feet long and detachable.
beer
Re: finally built some drive on ramps........... [Re: moparx] #3222358
03/23/24 01:50 PM
03/23/24 01:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very nice!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: finally built some drive on ramps........... [Re: moparx] #3222377
03/23/24 04:29 PM
03/23/24 04:29 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Looks very robust ! You have plenty of room uner ther now . Well done . Gary
Re: finally built some drive on ramps........... [Re: Gabby63] #3222386
03/23/24 06:05 PM
03/23/24 06:05 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Nice work!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: finally built some drive on ramps........... [Re: moparx] #3222387
03/23/24 06:08 PM
03/23/24 06:08 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Nice! I have the same problem. Wish I had a set of those.
Re: finally built some drive on ramps........... [Re: moparx] #3222497
03/24/24 10:55 AM
03/24/24 10:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
A necessary pita….. so many tasks that are nicer to perform with jackstands NOT in the way. Assuming the square of the base is still rock solid with the additional height. Noted those holes in the bracket at the rear by the ramps….. is there an additional cradle that mounts there to secure the wheel?
Re: finally built some drive on ramps........... [Re: J_BODY] #3222509
03/24/24 12:06 PM
03/24/24 12:06 PM
BDW Offline
BDW  Offline
Look nice, any concerns about no lip on drive up side?
I’m paranoid and worried my plastic ramps might let it roll back.
Mine seem dicey when up on them and I go to jack up rear, seems like a lot of movement.
Re: finally built some drive on ramps........... [Re: J_BODY] #3222548
03/24/24 02:29 PM
03/24/24 02:29 PM
moparx Offline OP
moparx  Offline OP
very solid, as the base measures 12 wide by 14 long.
the extra holes at the rear are for bolt on wheel stops like are at the front, which are welded fast.
the first time drive up those was somewhat nerve wracking, as the angle of the ramps is steeper that what i had expected, even though they are four feet long.
the length was what worked out with what material i had in the pile.
i stopped at several intervals to get out and measure the ramps for any deflection. there was none. boogie
even though i jumped around a lot, and tried to weld so the deflection was minimal when the weld cooled, i still had a built in "bow" in both ramps.
al in all, i'm pretty satisfied with how they turned out, and it sure beats having the floor pan only an inch from your face like most all available ramps position it.
beer
Re: finally built some drive on ramps........... [Re: moparx] #3222549
03/24/24 02:32 PM
03/24/24 02:32 PM
moparx Offline OP
moparx  Offline OP
forgot to add, they are made from 1/8 and 3/16" material, with a little 1/4" here and there.
i don't think they will fall apart any time soon. biggrin
beer
Re: finally built some drive on ramps........... [Re: moparx] #3222563
03/24/24 03:48 PM
03/24/24 03:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
How do you get it to go up that high of a ramp? I have trouble sometimes with my cars pushing a standard ramp when trying to go up them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: finally built some drive on ramps........... [Re: moparx] #3222627
03/25/24 06:17 AM
03/25/24 06:17 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work! Those would be handy.
Re: finally built some drive on ramps........... [Re: moparx] #3222667
03/25/24 12:13 PM
03/25/24 12:13 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
I'm not an engineer, nor did I stay at a Holiday Inn last night. However, my thoughts are there should be an "X" brace or similar on the open sides of the stand. I could be wrong. I just thought it was worth considering. up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: finally built some drive on ramps........... [Re: 6PKRTSE] #3222670
03/25/24 12:15 PM
03/25/24 12:15 PM
Missouri
randavis Offline
randavis  Offline
Missouri
Me too.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: finally built some drive on ramps........... [Re: randavis] #3222690
03/25/24 01:17 PM
03/25/24 01:17 PM
moparx Offline OP
moparx  Offline OP
Me too.
for my car with the converter stall it has, a steady power brake of 2000rpm was the ticket.
it took a couple of tries to figure out the best way, but that method worked like a charm, and the car smoothly drove up the incline with no drama whatsoever.
it sure was intimidating though !
beer
Re: finally built some drive on ramps........... [Re: MadMopars] #3222692
03/25/24 01:27 PM
03/25/24 01:27 PM
moparx Offline OP
moparx  Offline OP
as a fabricator with almost 46 years of my working career dedicated to design and fabrication, i thought that as well.
however, the top made from 1"x1 1/2", 1/8" wall tubing, plus the 3/16"x1 1/2" angle on the open side at the bottom made it seem unnecessary.
i tested that "theory" by turning them on their sides, and placing the front of my caravan on them to see if they racked out of square.
i may add an "x" or a diagonal in the future.
beer
Re: finally built some drive on ramps........... [Re: moparx] #3222810
03/25/24 10:41 PM
03/25/24 10:41 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
How much does one of those weigh?
Re: finally built some drive on ramps........... [Re: racerx] #3222883
03/26/24 12:59 PM
03/26/24 12:59 PM
moparx Offline OP
moparx  Offline OP
that is a great question, as i never weighed them.
with that said, my feeble old a$$ can pick them up [each piece separately, of course biggrin] without too much difficulty, although i can tell there is some heft there.
if i were to hazard a guess, 40-45lbs for each piece maybe ? shruggy
i know for sure they are way heavier than those cheap tin ramps that everybody has !
beer
Re: finally built some drive on ramps........... [Re: moparx] #3222899
03/26/24 01:44 PM
03/26/24 01:44 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
beer
Be careful up
Re: finally built some drive on ramps........... [Re: moparx] #3222906
03/26/24 01:56 PM
03/26/24 01:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice!
And I forgot how cool that car is smile
Rich H.
Esse Quam Videri
Re: finally built some drive on ramps........... [Re: ZIPPY] #3223110
03/27/24 12:19 PM
03/27/24 12:19 PM
moparx Offline OP
moparx  Offline OP
thanks Zippy ! bow
when i finally got it running again late last year, i played around with the tune a little, and it helped quite a bit. i'm going to play with it more this year in hopes of a slight improvement.
one thing i have done lately, is repair the [very] crusty inner fender under the battery box. even though the car only has almost 19k original miles, the batteries over the years have played the devil on the battery tray and inner fender.
i found a [way] smaller battery that has a bunch of cranking amps, so i made a new battery tray from stainless, and incorporated it into the inner fender repair.
i know the purists will be offended, but this car is really not anything special, and my ownership began with me buying it as a "total" back in 1970 when i worked at a body shop.
since it got back on the road after being repaired, it has never been "stock", so i don't mind modifying it whenever i feel like it. especially since under my stewardship, i have beat on it every chance i get. biggrin
i also ordered a new driveshaft from action machine. 3 1/2" .083 wall with solid 1350 joints. i'll find the next weak link, then reinforce it.
last year, i replaced the steel wheel/dog dish setup on the front with american 5 spoke wheels, and that really changed the cars look.
this year, new carpet [the old original stuff is just old and turning to dust], drive shaft and front loop [loop ready to install] and possibly new rear wheels.
the next caretaker will REALLY hate me if he wants to restore the car, but oh well ! laugh2
beer
