Re: New H.O Hurricane 6 worse fuel economy than 5.7 Hemi
[Re: Grizzly]
#3223356
03/28/24 01:39 PM
03/28/24 01:39 PM
Posts: 2,742 541 slobovia
A990
541 slobovia
You're a Goof with absolutely ZERO mechanical knowledge. Sit down.
Any idea if this thing will last longer than 30,000 miles in a tow/haul application?
[Re: d-150]
#3223393
03/28/24 04:40 PM
03/28/24 04:40 PM
Posts: 5,484 Michigan
oldjonny
Don't argue with me.
Straight 6 is much better then v6. If done right should be very reliable Like the GM 4.2 liter inline 6 that was in the Trailblazer? At the time I was working for a company that made the leak test equipment for the lost-foam casting blocks for those. Once they 'gross' leaked (porosity in the foam casting) they sent them into a secondary process to seal the pores. They were allowed to fail three times (being re-cycled thru the sealing process) before they were scrapped. Oil was leaking out of the sides of the engines....
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: A990]
#3223435
03/28/24 09:07 PM
03/28/24 09:07 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Any idea if this thing will last longer than 30,000 miles in a tow/haul application? What makes you think Chrysler can't build a head gasket, rings, pistons, rods, and a crankshaft that won't? When's the last time you saw a Slant 6 that died? Chrysler doesn't SCRAP their entire V8 lineup and replace it with this engine platform because it's a Turd, use Your head, Man. Try to imagine you control the Company, beating the Competition is your only goal, and the whole World is watching. Forced induction, small displacement, power and mileage is what sells. Blame Ford: they started it, Dodge is finishing it. Take a bow, Ford, you deserve it and Dodge is stepping up to the plate.
Mo' Farts
Moderated by "tbagger".
[Re: oldjonny]
#3223436
03/28/24 09:13 PM
03/28/24 09:13 PM
Posts: 6,018 Salem
Grizzly
Salem
OJ, please do not compare a Blunder Motors product to anything outside of an African Garden Tractor. Normally I say "Kia", but quality has really gone down hill at B.M. so have to be more creative and go to Third World countries. Thank-you.
Mo' Farts
[Re: d-150]
#3223438
03/28/24 09:14 PM
03/28/24 09:14 PM
Posts: 6,018 Salem
Grizzly
Salem
Straight 6 is much better then v6. If done right should be very reliable Indeed, thank-you D-150
Mo' Farts
[Re: 340Cuda]
#3223505
03/29/24 09:31 AM
03/29/24 09:31 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My guess is that if you drill down to the detailed emission numbers the Hurricanes come out better than the Hemis.
That is really what drives most all drive train decisions in my opinion. Money drives the decisions. One cylinder head and related parts. Simple inline block. One catalytic converter. Money says use inline engine.
[Re: d-150]
#3223538
03/29/24 12:50 PM
03/29/24 12:50 PM
A990
541 slobovia
Let's say slant 6- 258 4.0 6 -292 gm 6 -300 ford 6- Cummins six all very sturdy and yes take a look at boosted info on any of them with basically stock parts This new I-6 is only 182 CI. Per the article it copied a few design ideas from the 4.0 Jeep motor. Nice to know the block is closed deck. I would love to see a dyno sheet specifically for the torque curve.
