440 Cam Question
#322211
05/18/09 09:34 PM
05/18/09 09:34 PM
Hello Everyone, I am looking for a very mild performance cam for an upcoming 440 rebuild. The engine will be about 9 to 1 comp, mildly ported 516 heads, dual plane intake and headers. This is a street car (67 satellite) auto, probably 3.23 to 3.55 rear. Has anyone used the Edelbrock performer cam? Comments? I also saw an "Elgin: cam that has .449 int, .464 ex, 215/225@.050 and a 115 centerline. Any comments on that one? Any help would be greatly appreciated.
Re: 440 Cam Question
[Re: RemCharger]
#322213
05/18/09 11:29 PM
05/18/09 11:29 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i agree, with the xe 274, i have a 1973 motor home 440, running a ex 274/296 230/236, .488/.491 110, has mid range power and sounds awsome, i have not really had the car on the road much, i have driven around the neighbor hood, i running 3.55 suregrip, 440/727, ![](/ubbthreads/images/graemlins/thumbs.gif)
#322215
05/19/09 07:38 AM
05/19/09 07:38 AM
Thanks for the comments and suggestions. As afar as the stock 375 cam, what are the specs on that cam? The comp cams that was suggested, will it work well with a comp ratio of only 9-to-1?
Mike
[Re: Mr.Yuck]
#322217
05/19/09 10:08 AM
05/19/09 10:08 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
I agree the Summit cam kit for the money cant be beat.I had one in the 440 nice sound lots of power and still had decent idle.Its still running in my buddys 383 after almost 30 years.Rocky
Chrysler Firepower
[Re: GomangoCuda]
#322219
05/19/09 04:04 PM
05/19/09 04:04 PM
therocks
Niles , Ohio
Last 2 I got had Crane instructions in them.I would imagine Summit still has a ton.They dont just buy a 1/2 dozen They buy thousands at a time.Great cam for a budget build.Rocky
Chrysler Firepower
[Re: therocks]
#322220
05/19/09 05:07 PM
05/19/09 05:07 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It is a Crane, and FWIW it's tons better than an old purple shaft 484 in a lowish compression street pounding 440. It pulls well from off idle to around 5800, 6400 w/ 6 lbs of boost ![](/ubbthreads/images/graemlins/grin.gif)
[Re: Mr.Yuck]
#322221
05/20/09 11:32 AM
05/20/09 11:32 AM
therocks
Niles , Ohio
The first one I bought actually was a Cam Kinetics.Then the last 3 I got were Crane.Rocky
Chrysler Firepower
#322222
05/21/09 10:46 PM
05/21/09 10:46 PM
Thanks for all the comments. I have a couple of follow up questions. With the Summit cam, do I have to have adjustable push rods or rockers? Also, will a spring with a seat pressure of 90lbs and and open pressure 265lbs be ok?
Mike
#322223
05/22/09 08:23 AM
05/22/09 08:23 AM
Mr.Yuck
Brookeville, Md
Mike
Summit has push rods, all you need are stcok replacement. springs should be ok but ask the summit tech. If you need them they can set you up w/ a set of springs pretty cheap too.
