ET change from heat soak / hot lapping #3221904
03/21/24 01:13 PM
03/21/24 01:13 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I spent last Saturday at Capitol and Sunday at MIR getting significant seat time in the 1320 for the first time since 2022. This car has always been very sensitive to heat soak from being stuck creeping forward in long staging lanes, or when I've run two classes that are back-to-back and basically hot-lapping me.
How are you adjusting dial-ins under these conditions?
--> Do you have enough data to be able to predict (reasonably) accurately how much you'll slow down?
--> Are you taking a s.w.a.g. about how much to change the dial-in simply cuz you know the car's gotten hot?
I got in 10 passes on Saturday and all I can tell you is... yes, the car gets progressively slower as the cool-down intervals get shorter. Disregarding some changes in the DA for the time being, the car ran the following when "cold"... 45-60 minutes between passes:
11.857
11.856
11.876
When the cool-down interval was only 20-30 minutes:
11.978
11.946
When I intentionally hot-lapped the last 3 passes only about 8 minutes between them:
12.228 (spun)
12.024
12.059
So I'm wondering how other people account for this variability. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3221906
03/21/24 01:42 PM
03/21/24 01:42 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We used to do a track rental. The most that I ever got in was 27 passes in one day. This was with my mostly stock Charger cruiser street car. Stayed from 13:60'-13:80's all day. That car doesn't vary much every.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: ET change from heat soak / hot lapping [Re: 6PKRTSE] #3221907
03/21/24 01:49 PM
03/21/24 01:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Usually the first pass is .01-.02 slower because of fluid temps. Car usually repeats dead on after unless tremps or DA change radically. I've run 11.41 three in a row with no issues.
'63 Dodge 330
11.19 @ 121 mph
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3221917
03/21/24 03:19 PM
03/21/24 03:19 PM
Anchorage, Alaska
metallicareload Online content
metallicareload  Online Content
Anchorage, Alaska
How much time between runs is safe? @ some test and tunes we've been able to go from the return road straight to the burn out box shock
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: ET change from heat soak / hot lapping [Re: metallicareload] #3221943
03/21/24 05:57 PM
03/21/24 05:57 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I assume your engine coolant temp is well regulated? If so, I wonder if your fuel temps rising are what is responsible for the change.
I have "hot lapped" at Moparty as part of their "drag-n-drive" class, and my runs were pretty well identical back to back.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: ET change from heat soak / hot lapping [Re: 19swinger70] #3221947
03/21/24 06:15 PM
03/21/24 06:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run as quick as 13 minutes apart. Car is usually .01-.02 quicker due to hot lubes. If your car doesn't have a fan/water pump system that you can run with the engine off it's going to be slower. Best thing we've done. Don't shut it off. Let it idle. Yes it'll be slower. Yes it'll be consistent.
Doug
Re: ET change from heat soak / hot lapping [Re: 19swinger70] #3221994
03/21/24 09:03 PM
03/21/24 09:03 PM
Anchorage, Alaska
Anchorage, Alaska
Doug
It's a street car with electric fans and everything else stock, so it'll hold around 180 to 190 degrees water temp once up and running shruggy
440, 4-Speed, 3.54
Re: ET change from heat soak / hot lapping [Re: metallicareload] #3222014
03/21/24 10:17 PM
03/21/24 10:17 PM
Loudoun County, VA
Loudoun County, VA
The car has a 203* 'stat, but the big issue is while sitting I can watch the IAT climbing continuously until the car starts getting up to speed again
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3222046
03/22/24 07:21 AM
03/22/24 07:21 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Do you have a way to see air inlet temp? I bet it is much higher on a hot lap and the inlet sensor is also likely to respond pretty slow. It would be interesting to see if you could make a resistor that plugged in and locked the inlet air temp to a single number.
I moved my Barracuda over to a Rife brand inlet temp sensor because they respond very quickly. My car picks up under hood air from the hole in the hood at low speed and idle. So I leave the line with a higher than ambient inlet temp, sometimes as much as 30-60*. The original GM style inlet temp sensor is right at the top of the throttle body. With the GM sensor I start the run over ambient and it took almost the entire run for the sensor to read ambient again. With the Rife sensor it reads ambient almost immediately after I mash the throttle. That helped smooth out my tuning some because the slow response time was messing with the inlet air temp correction. I might have gained a few hundredths from this but for sure gained more accurate data. I am sure an OEM with border line safe compression ratios pulls timing and throttle response with higher inlet temps.
68 Barracuda Formula S 340
Re: ET change from heat soak / hot lapping [Re: Bad340fish] #3222139
03/22/24 02:00 PM
03/22/24 02:00 PM
Loudoun County, VA
Loudoun County, VA
Yes; there is an IAT gauge option that seems to give pretty quick response to changes in airflow. It's generally about 5* above ambient while the car is moving a a reasonable pace, but I can watch it keep getting hotter the longer I'm stuck waiting to move.
Those hot runs hurt right from the 60', too. It must take a big gulp of the heated air and pull the timing, then it ramps it back in as the IAT comes down as the car picks up speed.
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3222211
03/22/24 06:32 PM
03/22/24 06:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Have you tried running it with the IAT unplugged. It'll set a fault but in normal driving during tests I've never really felt a difference on numerous vehices.
Doug
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3222983
03/26/24 08:54 PM
03/26/24 08:54 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
My car is like yours. Always has been.
Last fall at test and tune.
>1 hr cool down:
11.762
11.761
11.789
Shorter cool down:
11.967 - < 5 minutes
11.916 - 13 minutes
11.892 - 31 minutes
After one pass the engine is so hot you can't touch anything under the hood. If I'm racing, I guess. But I suck, so that doesn't work. I got nothing for you.
Re: ET change from heat soak / hot lapping [Re: Brad_Haak] #3222999
03/26/24 09:43 PM
03/26/24 09:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have a Tazer it does lots of stuff, one of them is you can run the cooling fans to cool the car down
Re: ET change from heat soak / hot lapping [Re: dvw] #3223018
03/26/24 11:44 PM
03/26/24 11:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Doug
I would expect it to default to max IAT range and trim accordingly if you unplugged the sensor.
Kevin
