Tubular Control Arms #3221537
03/19/24 09:04 PM
03/19/24 09:04 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Front upper Tubular control arms for an A Body, is there much available other than the QA1 stuff?
What have people used?
Alan Jones
Re: Tubular Control Arms [Re: LA360] #3221539
03/19/24 09:20 PM
03/19/24 09:20 PM
Washington
skrews Offline
skrews  Offline
Washington
I have Reilly MotorSports tubular uppers.
Re: Tubular Control Arms [Re: skrews] #3221557
03/19/24 10:19 PM
03/19/24 10:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have what looks to be QA1 on my Roached Runner from Previous owner and I have Reilly Motorsports on my Challenger. Both work well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Tubular Control Arms [Re: 6PKRTSE] #3221564
03/19/24 10:33 PM
03/19/24 10:33 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
I use the SPC on my Challenger and have been very happy. +5 caster
Re: Tubular Control Arms [Re: LA360] #3221606
03/20/24 08:44 AM
03/20/24 08:44 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What is your goal by going to the tubular arms?
If the goal is a better range of adjustment, we have always just removed 1/4" or so from the stock rear arm combined with the offset bushings. Have done it many times. Works great with no problems. And lots cheaper than the tubular arms.
Master, again and still
Re: Tubular Control Arms [Re: DaveRS23] #3221742
03/20/24 07:11 PM
03/20/24 07:11 PM
LA360 Offline OP
LA360  Offline OP
I am intending on building a tubular K frame, like the old LRT K frame, so I have a front steer R&P. To also gain more castor. It's not for a street car.
Alan Jones
Re: Tubular Control Arms [Re: LA360] #3221810
03/20/24 10:57 PM
03/20/24 10:57 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have used Firm Feel Tubular UCA's on a few cars with no complaints.
The only Carbs I care about are under the hood!
Re: Tubular Control Arms [Re: Azzkikrcuda] #3221830
03/21/24 06:33 AM
03/21/24 06:33 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Assuming you want to use the larger 73-76 balljoint there are a litany of option from ebay to Firm Feel. For minimum resistance I would choose an arm with heim joints. If using an arm with poly bushings make sure it is greasable and that you use the correct silicone grease. I have used ebay tubular control arms and grovved the poly bushing in a lathe along with adding grease zerks. Careful with shock clearance on the ebay stuff.
To get maximum downward travel (UCA travel down as body rises) the frame rail upper lip will need to be trimmed where it interferes with the UCA. At that rate your binding is at the ball joints. Using high angle ball joints would be something to try although you would be on a mission of discovery there. If you can physically get more travel there will be an alignment issues to correct, especially in the bump steer measurement.
That said, a Mustang II style strut suspension calls for 2.5 degrees positive caster in a light weight tube car. What are your alignment goals?
Re: Tubular Control Arms [Re: DaveRS23] #3221855
03/21/24 09:24 AM
03/21/24 09:24 AM
Maryland
mrob Offline
mrob  Offline
Maryland
DaveRS23:
Can you please explain what you mean by "removed 1/4" or so from the stock rear arm"? The Moog offset bushings are pretty well known for increasing the adjustment range, but wasn't aware of any other mods to the control arm.
Re: Tubular Control Arms [Re: mrob] #3221888
03/21/24 12:26 PM
03/21/24 12:26 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I like the RMS upper control arms and strut rods. Mine have been on my car for almost 15 years and have done 9 drag weeks with no issues. My only complaint would be the ball joint boots have nothing to seat to so they just kind of exist and don't really seal up. That would probably be more of an more issue if I drove the car in all kinds of weather but I think the last time it got driven in much rain was Hurricane Florence in 2018 lol.
68 Barracuda Formula S 340
Re: Tubular Control Arms [Re: Bad340fish] #3221893
03/21/24 12:47 PM
03/21/24 12:47 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The A-arm mod goes back a long time - Jack Arnew was the guy back then at that stuff, and my ex-Hamburger had them.
A-arms are triangles, of course, so picture one as an upside down A, or more accurately a V.
Adding length to the front leg (Arnew) or subtracting length from the back leg, moves the point where they join backwards.
That tilts the spindle rearward at the top, increasing camber. Mine ran about 7 degrees, though 5 is adequate.
Re: Tubular Control Arms [Re: mrob] #3221974
03/21/24 07:57 PM
03/21/24 07:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Originally Posted by mrob
DaveRS23:
Any competent machine shop can cut 1/4" or so out of the rear arm near to the bushing end and weld it back. Actually, it wouldn't take a machine shop. There is no particular amount. Anywhere around 1/4" can be removed without too much trouble and gets you where you want to be. I was first introduced to this by the phord guys in the 70s. And I have been doing it ever since. Even before I was aware of the Moog offset bushings.
Re: Tubular Control Arms [Re: Jeremiah] #3221989
03/21/24 08:50 PM
03/21/24 08:50 PM
LA360 Offline OP
LA360  Offline OP
I am in the planning phase at the moment. I intend on the car being legal for our local Super Stock classes here in Australia, so the front end has to be a bolt in deal. If I wasn't going down this road, I would just put long travel struts in the front.
Aim at this point will be to use the standard pivot points and work it our from there, The ideal would be to get 6 or more degrees of caster, and 5-6 inches of travel, but that may not be possible.
Alan Jones
Re: Tubular Control Arms [Re: LA360] #3222001
03/21/24 09:32 PM
03/21/24 09:32 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a QA1 k member, UCA's, adjustable strut rods and stock LCA's with Proforged greasable LCA pins. I have an easy 5.5-6" of travel and the front end it not slammed on the ground. 5-6 degrees of caster should be no problem. I dialed in 4.5 in about ten minutes so with some strut rod tuning you will be able to gain positive caster.
I used Proforged ball joint and ties rods with aluminum tie rod adjusters. The drag link, idler arm and pitman arm have been changed to the 73-76 -style for header clearance.
I have used QA1 stocker star shocks as well as Viking DA's with good results with a 4 speed on an unprepped surface.
You should have no issue obtaining your goals IMO.
Re: Tubular Control Arms [Re: Jeremiah] #3222002
03/21/24 09:33 PM
03/21/24 09:33 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Here we are at niominal ride height:
