Tubular Control Arms
#3221537
03/19/24 09:04 PM
03/19/24 09:04 PM
Posts: 6,163 Melbourne , Australia
LA360
Front upper Tubular control arms for an A Body, is there much available other than the QA1 stuff?
What have people used?
Alan Jones
Re: Tubular Control Arms
[Re: skrews]
#3221557
03/19/24 10:19 PM
03/19/24 10:19 PM
Posts: 4,632 Motor City
6PKRTSE
Motor City
I have what looks to be QA1 on my Roached Runner from Previous owner and I have Reilly Motorsports on my Challenger. Both work well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: LA360]
#3221606
03/20/24 08:44 AM
03/20/24 08:44 AM
Posts: 12,801 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
What is your goal by going to the tubular arms?
If the goal is a better range of adjustment, we have always just removed 1/4" or so from the stock rear arm combined with the offset bushings. Have done it many times. Works great with no problems. And lots cheaper than the tubular arms.
Master, again and still
[Re: DaveRS23]
#3221742
03/20/24 07:11 PM
03/20/24 07:11 PM
LA360
If the goal is a better range of adjustment, we have always just removed 1/4" or so from the stock rear arm combined with the offset bushings. Have done it many times. Works great with no problems. And lots cheaper than the tubular arms. I am intending on building a tubular K frame, like the old LRT K frame, so I have a front steer R&P. To also gain more castor. It's not for a street car.
Alan Jones
[Re: LA360]
#3221810
03/20/24 10:57 PM
03/20/24 10:57 PM
Posts: 1,814 North Dakota
Azzkikrcuda
North Dakota
I have used Firm Feel Tubular UCA's on a few cars with no complaints.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#3221830
03/21/24 06:33 AM
03/21/24 06:33 AM
Posts: 9,112 Rogue River, OR
Jeremiah
Rogue River, OR
Assuming you want to use the larger 73-76 balljoint there are a litany of option from ebay to Firm Feel. For minimum resistance I would choose an arm with heim joints. If using an arm with poly bushings make sure it is greasable and that you use the correct silicone grease. I have used ebay tubular control arms and grovved the poly bushing in a lathe along with adding grease zerks. Careful with shock clearance on the ebay stuff.
To get maximum downward travel (UCA travel down as body rises) the frame rail upper lip will need to be trimmed where it interferes with the UCA. At that rate your binding is at the ball joints. Using high angle ball joints would be something to try although you would be on a mission of discovery there. If you can physically get more travel there will be an alignment issues to correct, especially in the bump steer measurement.
That said, a Mustang II style strut suspension calls for 2.5 degrees positive caster in a light weight tube car. What are your alignment goals?
[Re: mrob]
#3221888
03/21/24 12:26 PM
03/21/24 12:26 PM
Posts: 8,079 Tulsa OK
Bad340fish
Tulsa OK
I like the RMS upper control arms and strut rods. Mine have been on my car for almost 15 years and have done 9 drag weeks with no issues. My only complaint would be the ball joint boots have nothing to seat to so they just kind of exist and don't really seal up. That would probably be more of an more issue if I drove the car in all kinds of weather but I think the last time it got driven in much rain was Hurricane Florence in 2018 lol.
68 Barracuda Formula S 340
[Re: mrob]
#3221974
03/21/24 07:57 PM
03/21/24 07:57 PM
DaveRS23
Benton, IL.
DaveRS23:
Can you please explain what you mean by "removed 1/4" or so from the stock rear arm"? The Moog offset bushings are pretty well known for increasing the adjustment range, but wasn't aware of any other mods to the control arm.
Thanks Any competent machine shop can cut 1/4" or so out of the rear arm near to the bushing end and weld it back. Actually, it wouldn't take a machine shop. There is no particular amount. Anywhere around 1/4" can be removed without too much trouble and gets you where you want to be. I was first introduced to this by the phord guys in the 70s. And I have been doing it ever since. Even before I was aware of the Moog offset bushings.
[Re: Jeremiah]
#3221989
03/21/24 08:50 PM
03/21/24 08:50 PM
LA360
That said, a Mustang II style strut suspension calls for 2.5 degrees positive caster in a light weight tube car. What are your alignment goals? I am in the planning phase at the moment. I intend on the car being legal for our local Super Stock classes here in Australia, so the front end has to be a bolt in deal. If I wasn't going down this road, I would just put long travel struts in the front. Aim at this point will be to use the standard pivot points and work it our from there, The ideal would be to get 6 or more degrees of caster, and 5-6 inches of travel, but that may not be possible.
Alan Jones
[Re: LA360]
#3222001
03/21/24 09:32 PM
03/21/24 09:32 PM
Jeremiah
Rogue River, OR
I have a QA1 k member, UCA's, adjustable strut rods and stock LCA's with Proforged greasable LCA pins. I have an easy 5.5-6" of travel and the front end it not slammed on the ground. 5-6 degrees of caster should be no problem. I dialed in 4.5 in about ten minutes so with some strut rod tuning you will be able to gain positive caster.
I used Proforged ball joint and ties rods with aluminum tie rod adjusters. The drag link, idler arm and pitman arm have been changed to the 73-76 -style for header clearance.
I have used QA1 stocker star shocks as well as Viking DA's with good results with a 4 speed on an unprepped surface.
You should have no issue obtaining your goals IMO.
