383 vs 440 flywheel #3220839
03/16/24 02:52 PM
03/16/24 02:52 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Can they be swapped? Or is the 440 flywheel externally balanced.
Re: 383 vs 440 flywheel [Re: rapom] #3220841
03/16/24 03:19 PM
03/16/24 03:19 PM
AndyF Offline
AndyF  Offline
Depends on the application. Internally balanced flywheels can be interchanged as long as they are the same tooth count. Some engines are externally balanced and those most likely will not interchange.
Re: 383 vs 440 flywheel [Re: AndyF] #3220846
03/16/24 04:12 PM
03/16/24 04:12 PM
God's Country Maryland
GODSCOUNTRY340 Offline
383's were internally balanced, 440's with a steel crank were internally balanced so those flywheels will interchange; Now, cast crank 440's were externally balanced so those won't interchange with a 383.
Re: 383 vs 440 flywheel [Re: GODSCOUNTRY340] #3220850
03/16/24 04:26 PM
03/16/24 04:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some '70-'71 383's were externally balanced and so were some steel crank 440's with heavy rods.
Re: 383 vs 440 flywheel [Re: John_Kunkel] #3220852
03/16/24 04:35 PM
03/16/24 04:35 PM
You're probably right John but I've never seen a 383 with a cast crank, even the 2 bbl. engines I've had were steel cranks and internally balanced.
Re: 383 vs 440 flywheel [Re: GODSCOUNTRY340] #3220857
03/16/24 04:49 PM
03/16/24 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 383 vs 440 flywheel [Re: John_Kunkel] #3220861
03/16/24 05:05 PM
03/16/24 05:05 PM
IMGTX Offline
IMGTX  Offline
In addition to the balance weren't the pressure plate sizes often different?
10.5 vs 10.95/11 inch.
Re: 383 vs 440 flywheel [Re: IMGTX] #3220868
03/16/24 05:21 PM
03/16/24 05:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
it's 10.5/10.95" vs 11" First two use the smaller sized flywheel, latter uses the bigger flywheel.
Re: 383 vs 440 flywheel [Re: rapom] #3220878
03/16/24 06:12 PM
03/16/24 06:12 PM
AndyF Offline
AndyF  Offline
There are a lot of different flywheels, maybe six or more? between those two engines. Small clutch, big clutch, internal balance vs. external balance and then the 440+6 type of flywheel which is another variation of the external balance.
If you have a 130 tooth, internal balance flywheel you should be able to swap it between multiple Mopar engines including SB, B and RB. But only if the rest of the assembly is compatible. (bellhousing, clutch, rotating assembly balance, starter, etc.)
Re: 383 vs 440 flywheel [Re: rapom] #3221104
03/17/24 06:06 PM
03/17/24 06:06 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What is your 440 , what is your 383 ??
Re: 383 vs 440 flywheel [Re: JohnRR] #3221214
03/18/24 12:18 PM
03/18/24 12:18 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
The flywheel and bellhousing are from a 70 383 from a challanger r/t. The 440 is from a 1978 motorhome. I wanted to install the 440 on an engine test stand and run it. The flywheel and bellhousing are needed to start it.
Re: 383 vs 440 flywheel [Re: rapom] #3221237
03/18/24 02:18 PM
03/18/24 02:18 PM
That motor, stock, is externally balanced, look at your flywheel to see if it was internally balanced or externally balance. if it has a bunch of small holes drilled or several large holes drill in it it might be external balanced confused wrench scope
Re: 383 vs 440 flywheel [Re: rapom] #3221247
03/18/24 03:52 PM
03/18/24 03:52 PM
U.S.S.A.
U.S.S.A.
The bellhousing and flywheel will bolt on, but you will need an external balance flywheel for that year 440.
Re: 383 vs 440 flywheel [Re: JohnRR] #3221327
03/18/24 10:09 PM
03/18/24 10:09 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Figures,
Well thanks for the info guys. At least I will be able to mock up my test stand while searching for a flywheel.
Re: 383 vs 440 flywheel [Re: rapom] #3221371
03/19/24 09:40 AM
03/19/24 09:40 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Figures,
No need to search. 440 source has a new billet flywheel, 130 tooth, and an add on weight for cast crank applications. Touch base with them to verify 440 cast crank. Under $250.
Re: 383 vs 440 flywheel [Re: rapom] #3221382
03/19/24 10:15 AM
03/19/24 10:15 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Figures,
440 Source has a balance weight that converts a flywheel from neutral balance to external cast crank balance for the rock bottom price of $25.00
Part # 200-1168
'63 Dodge 330
11.19 @ 121 mph
Re: 383 vs 440 flywheel [Re: GY3] #3221408
03/19/24 12:14 PM
03/19/24 12:14 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thank you, I will check it out.
Re: 383 vs 440 flywheel [Re: GODSCOUNTRY340] #3221514
03/19/24 07:17 PM
03/19/24 07:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have two 71 383's with cast cranks, but everything I have read is that they were for automatic transmissions only... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 383 vs 440 flywheel [Re: Rhinodart] #3221579
03/19/24 11:33 PM
03/19/24 11:33 PM
The 1971 two barrel 383 motors got those cast cranks is what use to be said at the oild drag race seminar that Mopar put on before 1980 shruggy work
