Page 1 of 3 1 2 3
8 3/4 truck rearend #3221258
03/18/24 05:24 PM
03/18/24 05:24 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I posted a while back about a 8 3/4truck rear
It has tapered axels. With a large nut out side the drum
All I want from this is the housing and center section. Already have new axels
So my question is. How do I tear this thing down?
If remove large nut. How does the axel come out?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 8 3/4 truck rearend [Re: toplescuda] #3221271
03/18/24 06:15 PM
03/18/24 06:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Take the nut off. Rent or buy a hub puller to get the drums off.
Continue removing nuts and bolts until something falls off.
Angry white pureblood male
Re: 8 3/4 truck rearend [Re: ruderunner] #3221286
03/18/24 07:37 PM
03/18/24 07:37 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Ok. Put it this way.....what exactly holds the axels in place?
1971 charger
Re: 8 3/4 truck rearend [Re: toplescuda] #3221296
03/18/24 08:04 PM
03/18/24 08:04 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Probably the same 4 nuts and studs that hold the axles in on any other 8 3/4 rear end.
As already stated, you have to pull the drums first to get at any of it.
The main difference is that the hub flange/drum assembly is held on by the nut on the end of the axle flange instead of the axle flange having the wheel flange being forged as part of the axle.
Re: 8 3/4 truck rearend [Re: SNK-EYZ] #3221307
03/18/24 09:07 PM
03/18/24 09:07 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
So the flange with the wheel studs. Is not the axel?
1971 charger
Re: 8 3/4 truck rearend [Re: toplescuda] #3221312
03/18/24 09:27 PM
03/18/24 09:27 PM
IMGTX Offline
IMGTX  Offline
Correct.
The axle is in the middle of the nut and the flange & drum will come off as one like a front brake drum with the hub/flange.
Axle without drum.
https://www.ebay.com/itm/204572899030?
Re: 8 3/4 truck rearend [Re: toplescuda] #3221313
03/18/24 09:34 PM
03/18/24 09:34 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Yes and no, it is not the actual axle.
The axle is in the center of it is the axle and the nut holds the flange on the axle.
You have to remove the nut, then the brake drum/hub assembly with a puller.
Here's a link to some info with pics from another forum.
https://www.google.com/url?sa=i&...CBUQjhxqFwoTCLjg2-CW_4QDFQAAAAAdAAAAABAE
There's pics of a service manual stuff there.
Re: 8 3/4 truck rearend [Re: SNK-EYZ] #3221320
03/18/24 09:54 PM
03/18/24 09:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's a two piece axle. You have an axle shaft and an axle flange. No great mystery here, Chrysler used this setup till 64 in pass cars, later in trucks.
You have to remove the nut to pull the flange.
You have to pull the flange to unbolt the bearing retainer to pull the shaft.
You will need a GOOD puller to get the hub off. The kind you use a 5lb sledge on.
When I did this to my 51 Plymouth I had to let the puller sit overnight under pressure before I could get passenger side flange off.
This is the puller
https://www.amazon.com/gp/product/B074QQCTH8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: 8 3/4 truck rearend [Re: SNK-EYZ] #3221321
03/18/24 09:54 PM
03/18/24 09:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the drum and hub are two separate pieces held together by swaging the lug studs. The axle/hub are tapered with a square key to keep it from spinning.
they can be a SOB to get apart even with the correct puller. it is a god idea to keep the nut at the end of the threads as the axle will mushroom if really stuck. it also prevent the assembly from ejecting into any nearby object wink
Once a lot of pressure is applied, smacking the end of the puller and around the hub itself will sometimes vibrate things enough to break the bond between the tapers. A smoke wrench with a rosebud tip also works. beer
Re: 8 3/4 truck rearend [Re: toplescuda] #3221342
03/19/24 02:55 AM
03/19/24 02:55 AM
The bearing retainer on the axle bolts up to the axle housing up Same bolts hold the brake backing plate on also.
Be prepare to fight getting the left brake drum off even with a great puller whiney
wrench Good luck up
Re: 8 3/4 truck rearend [Re: Cab_Burge] #3221417
03/19/24 12:31 PM
03/19/24 12:31 PM
moparx Offline
moparx  Offline
having taken many of those drum/axle combos apart, using the puller, some come apart relatively easy, while others are a complete mofo [even with the puller] to get apart.
plan on a complete afternoon, or longer, to get them apart.
or just find and install a 66-72 complete truck rear and be done with it. [as i have done countless times]
just my opinion. your mileage will vary.
beer
Re: 8 3/4 truck rearend [Re: moparx] #3221524
03/19/24 07:59 PM
03/19/24 07:59 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well i dont have a puller but buddy does have a cutting torch
Being all I actually need/want is the housing and center pig.... can I cut the drums off?
1971 charger
Re: 8 3/4 truck rearend [Re: toplescuda] #3221531
03/19/24 08:27 PM
03/19/24 08:27 PM
IMGTX Offline
IMGTX  Offline
Autozone used to rent the axle puller and slide hammer.
I bought one of each just to be sure I would never need them because I had them. If I didn't I would need them twice a month. LOL
Other stores probably rent them too.
And yes you can just cut the drums or the back of the studs holding the bearings & backing plates on and pull the axle & drum.
Re: 8 3/4 truck rearend [Re: IMGTX] #3221549
03/19/24 09:57 PM
03/19/24 09:57 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Use a torch and cut the face off of the drums and you can unbolt the axles and then just keep what you need...
Everything you're not going to use is not something you're likely to sell to anyone else anyway...
You will need to get a set of 65 up car or later truck backing plates with drums in a matching set...
10" or 11" whatever you want to use with wheel cylinders and a hardware kit...
...FAFO...
Re: 8 3/4 truck rearend [Re: skicker] #3221570
03/19/24 10:43 PM
03/19/24 10:43 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If all you want is the center section, you can cut the drum just to the outside edge of the flange so you can remove the outer part of the drum. Then remove the brake shoes and use an end wrench to remove the nuts that are holding the axle bearing flange in place and pull the axles out like you would the normal flanged 8 3/4 axle shaft. Before you trash the old axle shafts, be sure any pinion spacer that might be in the center section doesn't stick to the old axle shafts.
You will want to test fit the axle shafts from the rear end you want to use the older center section in to be sure the later model axle shafts have the same spline count as the older side gears.
Re: 8 3/4 truck rearend [Re: poorboy] #3221598
03/20/24 07:51 AM
03/20/24 07:51 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would remove the nut and smack it with a sledge (not a hammer) first what can you loose. a lot quicker than cutting and all that bs.
Re: 8 3/4 truck rearend [Re: B1MAXX] #3221609
03/20/24 09:10 AM
03/20/24 09:10 AM
Removing the nut is the easy part, it is them dang taper hubs that suck getting off, especially the driver side puke rant
I forgot to add heating up with a torch to cherry red will help also if your using a puller up scope wrench
Re: 8 3/4 truck rearend [Re: Cab_Burge] #3221639
03/20/24 11:47 AM
03/20/24 11:47 AM
SW CO
HemiSportFury Offline
SW CO
I've had good luck putting the puller on it under a good load (tension) and then heating the hub with a torch and letting it sit over night. The next morning they basically fall off. This has working on hubs that have been on for over 50 years.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: 8 3/4 truck rearend [Re: Cab_Burge] #3221653
03/20/24 12:35 PM
03/20/24 12:35 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I hear ya but I cant believe that a sledge won't take it off in a few whacks if we're not trying to save anything from the backing plate out.
Re: 8 3/4 truck rearend [Re: B1MAXX] #3221796
03/20/24 10:03 PM
03/20/24 10:03 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Have you ever removed one of the tapered axle drums before?
I watched my boss, with 25 years of experience working on those tapered axle drums destroy an axle shaft trying to remove a drum once. He had all the correct equipment and he used every trick he had ever learned and it still didn't work. Sometimes they just don't come apart. He ended up cutting the drum and removing the brake shoes to get the axle out and replaced that axle with a junk yard axle shaft and drum.
Page 1 of 3 1 2 3
