Well They are done, I decided against either of the 2 zep products.
Carb on left was dipped in Berryman carb cleaner overnight. it came out , OK .
Carb on right I used a mixture of simple green 50/ 50 water mix. Soaked in cooled mixture overnight . After about an hour in the heated mix.
No sonic cleaners available locally.
So filled a cheap turkey roasting pan and heated it on outdoor gas grill set at lowest heat setting I could get it. Heated the mix for maybe 5-10 minutes . Then turned the grill off and dropped them in and let them soak for a bit
Hard to tell in pictures.
But I like the finish on the right one better ( it's the front Carb btw )
I'm sold
I want to thank Scott Smith on his advice on how to do them .
I owe ya one
