AFB step-up rods #3221135
03/17/24 08:20 PM
03/17/24 08:20 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Are two-step step-up rods interchangeable with three-step rods? Are the pistons the same length? Does it matter if the cover is domed or flat?
Re: AFB step-up rods [Re: ackpht] #3221164
03/18/24 02:06 AM
03/18/24 02:06 AM
The two step and three step primary jets are not alike, the rods need to match the jets, in the front.
AVS carbs. used the three step rods and jets a lot scope shruggy
I use to have carter AVS jet kit and let it get away realcrazy whiney
Re: AFB step-up rods [Re: Cab_Burge] #3221182
03/18/24 08:09 AM
03/18/24 08:09 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
You can convert it, but you need the matching top plate, piston also. Pretty sure the jets are the same.
Re: AFB step-up rods [Re: B1MAXX] #3221190
03/18/24 09:22 AM
03/18/24 09:22 AM
VA
dragon slayer Offline
VA
There were different pistons in some MOPAR type AFBs, but the standard piston is the same. For three step the Primary jets are taller, the rod is longer, and you use the cap with the protrusion. Spring rate was the same for most mopars. So that allows the rod to operate over a longer range and use the intermediate step.
If you're going to two step use the early standard jet (shorter), the 2 step rod and the flat cover.
