Re: Ever soaked a carb in either of these ???
[Re: topside]
#3220649
03/15/24 03:45 PM
03/15/24 03:45 PM
Posts: 870 Keizer, Oregon U.S.A.
elmor353
Thirty years back, I worked for a local auto parts store. I bought a 5 gallon bucket of Berryman Chem-Dip. This stuff really worked. A few years ago, I bought another bucket. It is NOT the same stuff. I didn't get the same cleaning as the old formula. I've started soaking stuff in a 50/50 mix of Castrol Super Clean and water.
[Re: topside]
#3220653
03/15/24 04:04 PM
03/15/24 04:04 PM
Posts: 1,825 South Bend
John Brown
South Bend
Zep Driveway Cleaner contains sodium hydroxide aka lye. Be very careful using it on anything made from aluminum. May cause it to turn black if not washed off soon enough after it does it's work. Will EAT the whole thing if left in it for a long period of time.
Zep C-L-R contains Urea hydrochloride which is a salt formed from the simple mixture of urea with hydrochloric acid. Urea is the major chemical in p i s s, added to hydrochloric acid.
Not that I wouldn't use either of those chemicals, but I wouldn't drop a carb in either of them and walk away.
[Re: topside]
#3220656
03/15/24 04:20 PM
03/15/24 04:20 PM
Posts: 21,433 It's a dry heat
gtx6970
It's a dry heat
Just how bad are the carbs ?! (I'm assuming your Hemi carbs) Guess "carb cleaner" ain't what it used to be - the old stuff would stink up the whole garage and attack human skin. I THINK that CLR is OK on metal - FWIW, I was never all that impressed with it on porcelain. Maybe Evaporust is the go-to now. Just kinda yucky so to speak Ive had this same carb cleaner in the past and it always cleaned them up better than this Ive been reading on the net today and am not comfortable dropping a 1500 carb in it as a chance. I'll live with the carb cleaner outcome and call it good.
[Re: A12]
#3220679
03/15/24 06:46 PM
03/15/24 06:46 PM
Posts: 6,254 nowhere
Sniper
nowhere
[Re: elmor353]
#3220699
03/15/24 08:31 PM
03/15/24 08:31 PM
Posts: 948 Central Michigan
nuthinbutmopar
Central Michigan
Thirty years back, I worked for a local auto parts store. I bought a 5 gallon bucket of Berryman Chem-Dip. This stuff really worked. A few years ago, I bought another bucket. It is NOT the same stuff. I didn't get the same cleaning as the old formula. I've started soaking stuff in a 50/50 mix of Castrol Super Clean and water. Was that the metal bucket with the metal lid and came with a basket? Don't know about 30 years ago (1994) but the stuff we had in the late 70's-early 80's would strip the plating off a carb overnight and leave red chemical burns on your skin if you didn't wash it off right away. You could do a couple dozen carbs with the same bucket before it lost it's potency...
[Re: gtx6970]
#3220702
03/15/24 08:42 PM
03/15/24 08:42 PM
Posts: 15,366 Omaha Ne
TJP
Omaha Ne
They used to sell a wheel cleaner for non coated, unpolished wheels that did well on Carterbrock type carbs. Found this stuff that might work even better LINKY might find others with google And Chem Dip. Was good stuff but as mentioned wreaked for days. Clothes, hands anything it touched. not sure on the newer version
[Re: Cab_Burge]
#3220755
03/16/24 07:56 AM
03/16/24 07:56 AM
Posts: 1,326 VA
dragon slayer
VA
You only get so far with cleaning solutions and ultrasonic cleaner on a 50-year-old cast aluminum piece. Tumbling in a professional manner with proper media, or glass bead blasting is the only way to get a more correct finish and getting off the hard gunk. Any solution you put a carb in you need to look for the reaction, if you get heavy bubble gassing you need to remove it immediately. Even those brightener's and such do not actually brighten and are only soaked for 2 minutes for a passive coating.
[Re: dragon slayer]
#3220769
03/16/24 10:12 AM
03/16/24 10:12 AM
Posts: 10,718 North Dakota
6PakBee
North Dakota
You only get so far with cleaning solutions and ultrasonic cleaner on a 50-year-old cast aluminum piece. Tumbling in a professional manner with proper media, or glass bead blasting is the only way to get a more correct finish and getting off the hard gunk. Any solution you put a carb in you need to look for the reaction, if you get heavy bubble gassing you need to remove it immediately. Even those brightener's and such do not actually brighten and are only soaked for 2 minutes for a passive coating. What is the proper media?
[Re: scottk]
#3221187
03/18/24 09:14 AM
03/18/24 09:14 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Be sure to use the aluminum safe simple green, Original simple green is caustic and corrodes/oxidizes aluminum and or pot metal. Heat is critical as well, get you solution in the ultra sonic to about 140-150F.
[Re: Cuda340]
#3221257
03/18/24 05:22 PM
03/18/24 05:22 PM
gtx6970
It's a dry heat
Be sure to use the aluminum safe simple green, Original simple green is caustic and corrodes/oxidizes aluminum and or pot metal. Heat is critical as well, get you solution in the ultra sonic to about 140-150F. Picked up some today Now shopping for an ultrasonic cleaner to give this method a try I have a 727 to do next. so might as well pick one up.
