Re: Ever soaked a carb in either of these ??? [Re: gtx6970] #3221445
03/19/24 02:15 PM
03/19/24 02:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Methyl Ethyl Ketone used to be the active ingredient in any carb cleaner that actually worked.
Kevin
Re: Ever soaked a carb in either of these ??? [Re: gtx6970] #3221456
03/19/24 03:04 PM
03/19/24 03:04 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Well They are done, I decided against either of the 2 zep products.
Carb on left was dipped in Berryman carb cleaner overnight. it came out , OK .
Carb on right I used a mixture of simple green 50/ 50 water mix. Soaked in cooled mixture overnight . After about an hour in the heated mix.
No sonic cleaners available locally.
So filled a cheap turkey roasting pan and heated it on outdoor gas grill set at lowest heat setting I could get it. Heated the mix for maybe 5-10 minutes . Then turned the grill off and dropped them in and let them soak for a bit
Hard to tell in pictures.
But I like the finish on the right one better ( it's the front Carb btw )
I'm sold
I want to thank Scott Smith on his advice on how to do them .
I owe ya one
Re: Ever soaked a carb in either of these ??? [Re: gtx6970] #3221551
03/19/24 10:04 PM
03/19/24 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for sharing the pic's and methods used up
Re: Ever soaked a carb in either of these ??? [Re: Twostick] #3221601
03/20/24 08:04 AM
03/20/24 08:04 AM
VA
dragon slayer Offline
VA
Going to need a big ultra sonic cleaner for that case grin
