What heat range plugs? #3220526
03/14/24 11:41 PM
03/14/24 11:41 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
I've got a 440 with Stealth heads. Compression is about 8.2:1 as it's a late '72 engine form an RV, but does have a forged crank. I running a Lunati roller cam with these specs:
Advertised Intake Duration: 270
Advertised Exhaust Duration: 278
Intake Duration at .050 Inch Lift: 219
Exhaust Duration at .050 Inch Lift: 227
Intake Valve Lift: 0.515
Exhaust Valve Lift: 0.530
Lobe Separation: 110
Intake Center line: 116
Running an FBO electronic ignition with one of their custom curved distributors tailored to this cam. My question is this, what heat range plugs should I be running? I use NGK and prefer to stick to these. The car is a heavy Newport convertible I use as a cruiser and freeway runner. Any suggestions?
Re: What heat range plugs? [Re: carrman] #3220543
03/15/24 06:52 AM
03/15/24 06:52 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not sure if the cam specs are listed correct but that's not relevant here. An 8:1 aluminum-headed motor is going to want a plug hot enough to survive the surface of our sun IMO. This is a general guide the particular manufacturer is a matter of choice but I'd also hunt for an extended reach plug.
Re: What heat range plugs? [Re: carrman] #3220725
03/15/24 10:18 PM
03/15/24 10:18 PM
NGK #5 or #6, I would try the # 6 first and go from there, way better to start with colder plug when testing new combinations twocents scope wrench up
Re: What heat range plugs? [Re: Cab_Burge] #3220731
03/15/24 10:38 PM
03/15/24 10:38 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Actually tis engine has a few thousand on it, just wondering if I'm running the right heat range for my plugs. Last set was some Autolite 3924's.
Re: What heat range plugs? [Re: carrman] #3220745
03/16/24 01:57 AM
03/16/24 01:57 AM
Do you have a picture of one, hopefully #7? up
Autolite # 3924 should be a 3/4 reach plug with a 5/8 socket size, not correct for stock iron heads scope
I am breaking a pump gas iron headed motor now for a local customer, I put a set of Champion RJ86Y in it shruggy
I was hoping to find some Champion RJ12YC or maybe even some RJ14YC or RJ10YC but no hope in my current stock whiney
Re: What heat range plugs? [Re: carrman] #3220882
03/16/24 06:46 PM
03/16/24 06:46 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
With that low of compression 8.2-1
NGK 7938 - BKR5E
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: What heat range plugs? [Re: bee1971] #3221155
03/17/24 10:41 PM
03/17/24 10:41 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Ordered a set of BKR5E-11.
Re: What heat range plugs? [Re: carrman] #3221165
03/18/24 02:08 AM
03/18/24 02:08 AM
Do you know how cold the # 11 are ?
Probably work great in a high compression blown or turbo charged motor with 12+ lbs. of boost on gasoline confused
Re: What heat range plugs? [Re: Cab_Burge] #3221268
03/18/24 06:03 PM
03/18/24 06:03 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
BKR6E-11 Are what I have in there now, they are one heat range colder than the ones I want to put in.
Re: What heat range plugs? [Re: carrman] #3221343
03/19/24 02:59 AM
03/19/24 02:59 AM
Is the 6# or the 11# the heat range on hose plugs.
I don't use NGK, Autolites or Champions for me up grin
Re: What heat range plugs? [Re: Cab_Burge] #3221379
03/19/24 10:11 AM
03/19/24 10:11 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
The #6 is the heat range and the 11 is the gap. #5 would be one step hotter
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
