Re: 2nd gen hemi valve guide / seal question [Re: JohnRR] #3221425
03/19/24 01:02 PM
03/19/24 01:02 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
Update, Seals are here and will go in today.
To verify,
I bring each cylinder up to TDC and adjust that cyls valves correct ?
Or just look in the valley area and put each lifter on the cam base circle and adjust as needed ?
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3221428
03/19/24 01:18 PM
03/19/24 01:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This
2011 Drag Pak Challenger
Re: 2nd gen hemi valve guide / seal question [Re: rickseeman] #3221430
03/19/24 01:19 PM
03/19/24 01:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It was straight on my computer. I don't know what to do.
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3221449
03/19/24 02:35 PM
03/19/24 02:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use the method using the starter with the plugs in the motor that works by bumping the motor over using the starter motor until the exhaust valve just starts to open and then set the intake valve clearance, next bump it over until the intake valve opens all the way and is real close to being close or close a tiny bit of crank travel and set the exhaust valve clearance wrench up scope
Re: 2nd gen hemi valve guide / seal question [Re: rickseeman] #3221469
03/19/24 04:09 PM
03/19/24 04:09 PM
It's a dry heat
It's a dry heat
I got it straight
Re: 2nd gen hemi valve guide / seal question [Re: gtx6970] #3221886
03/21/24 11:58 AM
03/21/24 11:58 AM
It's a dry heat
It's a dry heat
Valves all adjusted. New intake valve seals. And put the spark plug tube seals in while it was apart.
So hopefully no more oil getting in the tubes
Just waiting on intake gaskets now
The Milodon tube seals are on backorder. So took a chance with these Ebay versions. Worked perfect.
https://www.ebay.com/itm/196284907202
