Page 1 of 3 1 2 3
toll used to hold pinion yolk while torqueing nut ? #3220175
03/13/24 01:02 PM
03/13/24 01:02 PM
moparx Offline OP
moparx  Offline OP
anyone have a picture or two of your home made tool used to hold the pinion yolk while you torque the nut to spec ?
i'm changing to a 1350 yolk on an 8 3/4, and want something more accurate to torque the nut other than an impact gun.
a big TIA ! bow
beer
Re: tool used to hold pinion yolk while torqueing nut ? [Re: moparx] #3220184
03/13/24 01:27 PM
03/13/24 01:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
One I first saw as a teenager that I now own in the article at https://www.hamtramck-historical.com/NostalgiaAndOldCars.shtml
Re: toll used to hold pinion yolk while torqueing nut ? [Re: moparx] #3220189
03/13/24 01:34 PM
03/13/24 01:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A large pipe wrench works to hold the yoke.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: John_Kunkel] #3220204
03/13/24 02:34 PM
03/13/24 02:34 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Search Ebay or Amazon.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: moparx] #3220213
03/13/24 03:33 PM
03/13/24 03:33 PM
AndyF Offline
AndyF  Offline
I make those tools as well as a bunch of other tools for working on Mopars.
https://arengineering.com/home-page/tools
Re: toll used to hold pinion yolk while torqueing nut ? [Re: AndyF] #3220218
03/13/24 04:15 PM
03/13/24 04:15 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have one that looks like yours in the middle there. Think I bought it off Mancini's (?) website many years ago.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: Neil] #3220229
03/13/24 05:03 PM
03/13/24 05:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Used one some time back that was basically a big, flat box-end wrench.
Box captured the diff yoke, lever was maybe 30" or so, and contacted the car's floor when tightening the nut.
Idiot-proof by my rating, since I used it successfully on my Dana 60.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: topside] #3220274
03/13/24 08:12 PM
03/13/24 08:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made one that bolts on now, but have always used a large pipe wrench as mentioned above also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: 6PKRTSE] #3220297
03/13/24 10:15 PM
03/13/24 10:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too)
Re: toll used to hold pinion yolk while torqueing nut ? [Re: Neil] #3220308
03/13/24 10:56 PM
03/13/24 10:56 PM
AndyF Offline
AndyF  Offline
Could be. I've been selling parts to Mancini for more than 20 years.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: moparx] #3220311
03/13/24 11:23 PM
03/13/24 11:23 PM
Out of the State of Confusion
blue_stocker Offline
This was a short piece of left-over roll bar tubing with a piece of 1/4" plate, clearanced rectangle around the companion (pinion yoke); works quite well!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: toll used to hold pinion yolk while torqueing nut ? [Re: John_Kunkel] #3220326
03/14/24 01:29 AM
03/14/24 01:29 AM
iagree that is what I use.
MoparX which third member are you working on?
If it is a "489" case then you need to know how much rotational torque it has both ways now before you loosen the nut up so you can tighten it back up enough to have 1 to 5 inch lbs. MORE rotational torque when your done scope wrench up
Re: toll used to hold pinion yolk while torqueing nut ? [Re: cudaman1969] #3220345
03/14/24 08:23 AM
03/14/24 08:23 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: Cab_Burge] #3220405
03/14/24 01:25 PM
03/14/24 01:25 PM
moparx Offline OP
moparx  Offline OP
MoparX which third member are you workoing on?
If it is a "489" case then you need to know how much rotational torque is has both ways now before you loosen the nut up so you can tighten it back up enough to have 1 to 5 inch lbs. MORE rotational torque when your done scope wrench up
working on a 741 case that is still in the car Cab.
i'm not a fan of using a pipe wrench due to the possibility of the teeth marking up the yoke.
i had thought about making a tool like the several that have been shown. i'll probably do just that, although as i get older, i find there is no such thing as a 5 minute [or 5 hour for that matter] job. laugh2
beer
Re: toll used to hold pinion yolk while torqueing nut ? [Re: moparx] #3220430
03/14/24 03:37 PM
03/14/24 03:37 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Mine is more simple. I’ve got a 3’ piece of heavy 2.5” angle iron with holes drilled to match the cap bolts and a enough clearance torched out of the center to work the nut.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: fastmark] #3220449
03/14/24 05:51 PM
03/14/24 05:51 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Done many with a 36" pipe wrench, don't ever remember " marking up a yoke". The pipe wrench doesn't have to be "killer tight" on the yoke. I remember doing a few rear end jobs before this, but I've done more of them since I've also gotten my 2 post lift... Thousands of times easier that way.that plus getting my son to come over and "man" the pipe wrench and cheater pipe while I tighten the yoke nut
Re: toll used to hold pinion yolk while torqueing nut ? [Re: volaredon] #3220452
03/14/24 06:06 PM
03/14/24 06:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
J-8514-11 Kent Moore. Couple of them on ebay right now. Probably find them at swap meets as well.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: CMcAllister] #3220477
03/14/24 08:20 PM
03/14/24 08:20 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Holding tool I made with some metal I had laying around.
Re: toll used to hold pinion yolk while torqueing nut ? [Re: 69Cuda340S] #3220519
03/14/24 11:26 PM
03/14/24 11:26 PM
up bow grin
I wish that had those skills, but I don't shruggy
I've had several different year FSM, some of them call for 120 Ft. lbs. torque on the 8 3/4 pinion nuts and some of them called for 150 Ft. lbs.torque when tightening those nuts. I end up using about a six-foot-long cheater pipe that will slide over my 1/2 drive clicker torque wrenches and then have someone hold the third member still while I torque that nut hammer wrench
Re: toll used to hold pinion yolk while torqueing nut ? [Re: Sniper] #3220577
03/15/24 11:05 AM
03/15/24 11:05 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy
Page 1 of 3 1 2 3
