Page 5 of 5 1 2 3 4 5
Milodon Rear Sump Oil Pan 360 [Re: GTX5877] #3219838
03/11/24 09:26 PM
03/11/24 09:26 PM
BigFish69 Offline
BigFish69  Offline
Milodon Rear Sump Oil Pan for a 360 used for two months like new. Includes pick up tube. $350 obo shipped
CP Carrillo small block 6.00 billet rods [Re: BigFish69] #3220020
03/12/24 07:36 PM
03/12/24 07:36 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
Fresh from CP Carrillo like brand new. 6.00", .927 pins and 2.100 crank journal. These rods retail $4000 and 6-8 month wait. Perfect for short deck (9.0-9.2"). Some of the best steel rods on the market came out of our back up engine with only a few dyno runs prior to being sent to CP. Asking $1200 shipped to the lower 48 states. Willing to ship worldwide.
Re: CP Carrillo small block 6.00 billet rods [Re: Swingin70] #3220318
03/13/24 11:52 PM
03/13/24 11:52 PM
Washington
skrews Offline
skrews  Offline
Washington
Edelbrock Performer RPM Air Gap 7576 SOLD
Plenum divider cut down 1/2 inch
Port matched to Fel Pro 1213 gasket
$350 plus the ride
located SE Wa
Pay Pal (plus fee) or USPS money order accepted
SOLD [Re: skrews] #3220416
03/14/24 02:14 PM
03/14/24 02:14 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
Sold
SOLD [Re: Swingin70] #3221274
03/18/24 06:26 PM
03/18/24 06:26 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
SOLD
Sold [Re: Swingin70] #3221288
03/18/24 07:51 PM
03/18/24 07:51 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
Sold
Holley 12R-4770B Base Plate [Re: Swingin70] #3221717
03/20/24 05:50 PM
03/20/24 05:50 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
Sold!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Indy Low Deck Mod Man Intake w/ 2-4 Top [Re: A70Runner] #3222272
03/22/24 10:40 PM
03/22/24 10:40 PM
Wisconsin USA
Albert Lee Offline
Albert Lee  Offline
Wisconsin USA
For Sale: Used Indy Mod Man Intake for
Low Deck 383-400 Mopar with 2-4 Top
$900 (They're 1300 new). Located in WI.
Text me for pics as I can't seem to post
them. Al Corda 6one2 9six3-4five4o
I rarely see PMs so just pick up the phone.
Re: For Sale - Race Parts - 1st Quarter [Re: dsd70bee] #3222886
03/26/24 01:05 PM
03/26/24 01:05 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
For sale:
One pair Calvert 9 way adjustable rear shocks
#22142
Ran on my 69 Dart
Some superficial outer dents, perform as they should
$175.00 plus shipping from 06492
PM me here
R3 billet water pump spacers from Brett Miller/Harshman [Re: actionange] #3223226
03/27/24 08:29 PM
03/27/24 08:29 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
Brand new billet water pump spacers for R3 blocks with or without Jesel front drive distributor.
These are 1.5" thick water pump spacers for a 9.0/9.2/9.6 deck small block mopar. Both sides have o-rings, so no silicone is necessary.
Asking $175 shipped to lower 48
Powermaster Race Alternators 8142 12V 150 amp [Re: Swingin70] #3223227
03/27/24 08:31 PM
03/27/24 08:31 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
11 passes form brand new, DMI bracket included. Asking $350 shipped to lower 48
Brand:
Powermaster
Manufacturer's Part Number:
8142
Alternator Case Style:
Denso
Advertised Amperage Output:
150 amps
Color:
Black
Coating Type:
Powdercoated
Voltage Compatibility:
12
One-Wire Capable:
Yes
Regulator Included:
Yes
Alternator Regulator Location:
Internal
For use with one wire, racing applications only. 118mm case is machined for use with Powermaster brackets. 0.669 in. shaft size.
Powermaster race alternators supply horsepower for your ride by ensuring the electrical and ignition systems have enough voltage to operate properly. This means your battery stays fully charged and predictable—you don't have to worry about your car not starting at race time. They feature a variety of high-amperage ratings, one-wire hookup, a gold battery post, and a heat-dispersant coating. Some models also include a pulley. Order the alternator designed for your vehicle application.
SOLD [Re: Swingin70] #3223228
03/27/24 08:32 PM
03/27/24 08:32 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
SOLD
Autometer Gauges & 4.86 Gear 8 3/4 [Re: Swingin70] #3223231
03/27/24 09:00 PM
03/27/24 09:00 PM
BigFish69 Offline
BigFish69  Offline
Autometer Pro Comp Ultra Lite Water Temp and Oil Pressure Gauges 2 5/8 - $100 sold
Yukon 4.86 gear & 31 spline spool for 8 3/4. Four 1/8 mile runs on both, like new - $200
Re: Autometer Gauges & 4.86 Gear 8 3/4 [Re: BigFish69] #3223580
03/29/24 07:43 PM
03/29/24 07:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have for sale a Bob Book BRX-Jr twin blade carb. Will fit 4150 or 4500 intake. Was $2550 new from Book 10 years ago! I will also include a few pieces, the throttle cable bracket and a spacer for a 4500 intake if you want to use it. It was purchased to try and run NSS classes but out here in the west they don't care. So I no longer need it. It was on a 540" B1 and ran in the 8's with this carb and a pretty "mundane" bracket engine. It is a trick piece I just don't see myself using it anymore. Has very little use on it now, I kept it more for the novelty of running it. I would say it has under 40 passes in its life. Ill just run my 64 in brackets and S/C out here. My loss is someone's gain. PM me here, text or call me at 7 zero 7 9 8 zero 2 one 67 or email me at b1valiant@hotmail.com. Asking $1000 OBO....
