71 cuda 4 speed wiring hole location? #3219756
03/11/24 03:10 PM
03/11/24 03:10 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Have a 71 cuda that I am doing some work to for a customer. It is a 340 4 speed car, Have the new wiring harness for the 4 speed that goes to the dash indicator. Car is all together but missing that. Wondering if anyone might have the location of the hold the wiring should be going through from the transmision up into the car?
corey
Contact Me about AMD Prices
Re: 71 cuda 4 speed wiring hole location? [Re: hotairballoonpilot] #3219781
03/11/24 04:52 PM
03/11/24 04:52 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Everything in this post has been copied/pasted from the e-bodies.org forum. It's noteworthy to say that 1970 Cuda reverse light is in a different location. Hopefully your firewall has a dimple there.
Re: 71 cuda 4 speed wiring hole location? [Re: EW1BH27] #3219807
03/11/24 07:13 PM
03/11/24 07:13 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Is that an undrilled hole on auto trans cars? If so, it sounds like a good way to determine a 3 speed or 4 speed car.
Re: 71 cuda 4 speed wiring hole location? [Re: A990] #3219894
03/12/24 08:13 AM
03/12/24 08:13 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I found this of a '71 Cuda and it shows the dimple (undrilled hole) location. Also read somewhere that the hole for a '70 is 3/4" and a '71 is 1", best to measure the grommet you have.
https://barnfinds.com/rolling-project-1971-plymouth-cuda/
Re: 71 cuda 4 speed wiring hole location? [Re: EW1BH27] #3219976
03/12/24 01:55 PM
03/12/24 01:55 PM
South Dakota
South Dakota
thank you! that will help out a lot once I get the car back up in the air!
corey
Re: 71 cuda 4 speed wiring hole location? [Re: hotairballoonpilot] #3219978
03/12/24 01:56 PM
03/12/24 01:56 PM
South Dakota
South Dakota
also never would have guessed 70 and 71 be different.
