Re: Mcleod throwout bearing
[Re: sogtx]
#3219339
03/09/24 04:39 PM
03/09/24 04:39 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
The biggest problem with throwout bearings today seems to be in the low quality grease they are filled with. It's just doesn't do the job, and the nature of the design makes it difficult to wash out the cheap grease and refill it with a high quality grease.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: sogtx]
#3219797
03/11/24 05:49 PM
03/11/24 05:49 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Andy I always thought the smaller bearing was used on the factory style 3 finger plate and the larger bearing was used on the diaphragm style plate. Some companies probably sell the larger bearing as a one fits all so they only need to stock one bearing. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
