Aluminum block. Bush lifter bores or not? #3218892
03/07/24 05:05 PM
03/07/24 05:05 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
New KB block. Priority oiling. Has lifter oil galleys. Jesel tie bar lifters with oil feed to axles. Going to machine shop next week. If lifter bores check good. Run the .060 lifter galley restrictors at rear of block and run in the aluminum bores. Or spend the 1k for bushings with .020 oil holes?
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3218899
03/07/24 05:44 PM
03/07/24 05:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What is the intended use for the block?
Re: Aluminum block. Bush lifter bores or not? [Re: Al_Alguire] #3218919
03/07/24 06:54 PM
03/07/24 06:54 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Al 90% street. 572 hemi. Some local track street car events. nothing competitive. Cost is not the issue, Longevity is a concern between freshen up..
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3218931
03/07/24 07:35 PM
03/07/24 07:35 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
All the aluminum blocks I have owned and seen have the bushings. Myself I would spend the money and bush them. Especially if it will see the miles of some street duty.
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3218993
03/07/24 10:47 PM
03/07/24 10:47 PM
AndyF Offline
AndyF  Offline
Ask KB if they have any feedback. My guess is that you wouldn't need bushings since you have drilled oil galleries. So the lifters are going to be flooded with oil whenever the engine has oil pressure. I suppose it might depend on how big the valve springs are. If you run an Accusump the engine will have oil pressure during cranking so the lifters will always be operating on an oil film.
Re: Aluminum block. Bush lifter bores or not? [Re: jwb123] #3218995
03/07/24 10:55 PM
03/07/24 10:55 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
My guess is the lifters are going to be tight. So the real cost to bush is $1,000 minus his price to hone. That will make it easier for you to decide because the bush price is now reduced. With all that said I still wouldn't bush. But thats just me.
2011 Drag Pak Challenger
Re: Aluminum block. Bush lifter bores or not? [Re: AndyF] #3219002
03/07/24 11:30 PM
03/07/24 11:30 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Andy I will be running an accusump for prelube and a little safety cushion. When I last talked to Tim Banning. At that time he said it is personal preference. If unbushed run a .060 restrictor at the rear of block in each lifter galley. He said if running bushings put a .023 to .025 oil hole in each bushing if lifters have pressurized oiling. Valve spring open pressure in the 650lb. range. It is a street engine so looking for best option for its intended use. I always appreciate the input on this site. Galen
Re: Aluminum block. Bush lifter bores or not? [Re: rickseeman] #3219003
03/07/24 11:35 PM
03/07/24 11:35 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks Rick. I thought if I could get away without bushing them it gives me an option down the road if the bores wear out or I damage a lifter. Appreciate the response. Galen
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3219035
03/08/24 05:51 AM
03/08/24 05:51 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Just for info, we got our KB block in 2009. We've ran it since then with no lifter oiling and no bushing. Always used solid roller cams and we have had no issues
Re: Aluminum block. Bush lifter bores or not? [Re: Tig] #3219041
03/08/24 08:22 AM
03/08/24 08:22 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Tig did you all use some sort of prelude (Peters/accusump )?
Re: Aluminum block. Bush lifter bores or not? [Re: Tig] #3219043
03/08/24 08:34 AM
03/08/24 08:34 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
X2
Re: Aluminum block. Bush lifter bores or not? [Re: B1MAXX] #3219044
03/08/24 08:34 AM
03/08/24 08:34 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
X2
no pre lube either.
Re: Aluminum block. Bush lifter bores or not? [Re: racerx] #3219055
03/08/24 10:32 AM
03/08/24 10:32 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Didn't for many years, fitted an accusump after the car developed a habit of wheelstanding. Though we always pre-lubed the engine with a drill if it had been standing for a couple of weeks or so.
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3219068
03/08/24 11:23 AM
03/08/24 11:23 AM
AndyF Offline
AndyF  Offline
Those aren't killer springs and you'll be pre-lubed so I'd just check the fit on the lifters and run them if the clearance is correct. I assume the car is kept in a garage so it won't develop rust or corrosion problems inside the engine.
Re: Aluminum block. Bush lifter bores or not? [Re: AndyF] #3219091
03/08/24 01:21 PM
03/08/24 01:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO it is not a necessary thing since you are staying with a stock lifter diameter and mainly a street car with very mild spring load. FWIW I have run a LOT more spring pressure on a non bushed KB block with no issues. I always have an accumulator on my wet sump hoopties.
Re: Aluminum block. Bush lifter bores or not? [Re: galen] #3219142
03/08/24 06:36 PM
03/08/24 06:36 PM
My KB street wedge aluminum block came with bushings up
I would have them added by a good shop so I wouldn't have to worry about not having them.
I have one set of the older special Crane chrome solid roller lifters design to be run in aluminum blocks with no bushings. shruggy
I may end up running them in my new 572 C.I race motor with that block, maybe not confused
Re: Aluminum block. Bush lifter bores or not? [Re: Cab_Burge] #3219308
03/09/24 02:49 PM
03/09/24 02:49 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I was expecting the majority of the replies to say add the bushings... surprised to hear the bare aluminum bores hold up
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Aluminum block. Bush lifter bores or not? [Re: B1MAXX] #3219902
03/12/24 08:50 AM
03/12/24 08:50 AM
an8sec70cuda Offline
X2
iagree Same here. Been running my KB block since 2006 w/ no lifter oiling and no problems at all. Street and strip w/ a solid roller cam.
No prelube either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum block. Bush lifter bores or not? [Re: an8sec70cuda] #3220018
03/12/24 07:00 PM
03/12/24 07:00 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Appreciate all the response. I will run them on the aluminum bores with the .060 restrictors in the oil galleys. If need ever arises I can bush them hopefully a few years down the road. Money I can use in a different direction right now is a plus. Thanks everyone.
