Re: re-using Magnum lifters, or no?
[Re: Mad-Max]
#3215605
02/23/24 01:02 PM
02/23/24 01:02 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Pushrod length-
[Re: B1MAXX]
#3216839
02/28/24 03:05 PM
02/28/24 03:05 PM
Posts: 246 Falcon, CO
Mad-Max
Falcon, CO
ok - I got a set of Melling MPR-667 (6.792" - and they measure out almost dead nuts), and installed two of 'em, along with re-installing fresh snap rings. With zero-lash of 6.764 these Melling 6.792s should be perfect...at least on paper.
Bottom line - it's good...I think. If I'm measuring right preload looks to be in the .015 - .020 range, and, when up on a lobe the snap rings will rotate all the way around in their groove. For sure there is positive preload with everything bolted tight, and the snap rings will rotate around without contacting the pushrods.
Topline says the lighter (<.030) preload is just fine, so I'm gonna run it as-is. And I'm hopeful my engine 'chatter' will be all but gone.
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
[Re: Mad-Max]
#3218031
03/04/24 03:14 PM
03/04/24 03:14 PM
Mad-Max
Falcon, CO
...ok - I'll take the lack of negative responses to the my preload query as a 'good' thing...and press on Good research project - thanks for everyone's inputs. It'll be a couple months before I'm close to firing the engine, and I'll of course report back then. - Sam
