Re: Using factory chain cover with striker crank [Re: AndyF] #3217621
03/03/24 02:36 AM
03/03/24 02:36 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by AndyF
Are you using a piston stop to find TDC? A piston stop and a degree wheel is usually the best way to find TDC. A dial indicator on a piston is usually too vague.
Agreed on the accuracy of the piston stop. Agreed on the vague TDC measurement with a dial indicator, but only if you try to use the dial to try to stop at TDC. Due to the dwell. But if you use the dial indicator in the same manner as a piston stop, measuring .200 before and .200 after TDC, marking the damper at each and finding the center, if think the dial indicator method is accurate. twocents
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Using factory chain cover with striker crank [Re: Cab_Burge] #3217636
03/03/24 09:03 AM
03/03/24 09:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Molnar crank and ATI damper cab.
Re: Using factory chain cover with striker crank [Re: AndyF] #3217640
03/03/24 09:14 AM
03/03/24 09:14 AM
Mt Morris Michigan
Mt Morris Michigan
Surprised to find the old cover that far off, but it is what it is. I guess the tolerances could stack up. I was having a blowby issue and thought it may have to much timing on this 12.5:1 511, so backing the timing down from 36 to 34 seemed to help, but the 34 was really 30* as i now know. Seat of the pants it ran no different, actually thought it ran better, but with less vacuum. So, will see how this all pans out once driving season comes back around and keep an eye on the plugs.
