Re: stage 5 hemi heads
[Re: mopar dave]
#3217949
03/04/24 10:11 AM
03/04/24 10:11 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I went to the stage v site and it looks like the custom heads can be ordered with different angle valve and raised or standard exhaust port. I do not know which i have. Those look like raised exhaust to me. With careful measuring with an iphone or one of these you can tell if your exhaust is stock 23 degree or 21-1/2 degree. If you have a 2.375" intake (or similar) they will probably be 21-1/2 degree.
2011 Drag Pak Challenger
[Re: mopar dave]
#3217956
03/04/24 10:23 AM
03/04/24 10:23 AM
rickseeman
Stuttgart, Arkansas
I've never done tubular K but they sure look nice to me. Hopefully with rack and pinion and no torsion bars the headers would fit.
[Re: rickseeman]
#3218001
03/04/24 01:51 PM
03/04/24 01:51 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I've never done tubular K but they sure look nice to me. Hopefully with rack and pinion and no torsion bars the headers would fit. Yes, a tubular K frame does make it nice. I was able to weld up my multi-piece Super Comp Hemi Headers into 2 solid pieces. (1 complete header per side). I am able to slip them in up from the bottom on both sides and bolt up in minutes by myself. I did have to reconfigure the #1 tube around the steering shaft down to the rack.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
