Re: type F transmission fluid ??
[Re: bee1971]
#3217893
03/03/24 11:26 PM
03/03/24 11:26 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Type F
$4.49 at my local Fleet Farm I told him about our local Rural King but it sounds like he would rather pay shipping
[Re: Leigh]
#3217955
03/04/24 10:22 AM
03/04/24 10:22 AM
Posts: 324 Northport, al.
tvt59
Northport, al.
We use ATI 20w type F. Works good for us.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: GomangoCuda]
#3217991
03/04/24 12:51 PM
03/04/24 12:51 PM
Posts: 246 Cent, OH
Mopar.70
Cent, OH
When I mentioned the B&M blue Stuff i was being sarcastic. Guess I should have put a smiley on there. Nobody I know has used that snake oil for about 50 years. If the TranSynd runs significantly cooler then that would be worth paying for. Does it affect stall speed, et or consistency? Curious on the negative on this one. So I was instructed to use a mineral F in my race 727 and ended up picking this stuff. Used it last season, no issues but being first year out with the car I only got about 25 passes in. But no shift problems and no heat issues. I have a gage on the trans, thought it didn't work until one night I went a few rounds and it registered on the gage but never over 160. In my street car I use the ATI 20w previosuly mentioned as well. This has been one of the things that has drove me crazy as of late since the stuff that was orignally spec'ed for these is no longer available.
[Re: GY3]
#3217995
03/04/24 01:12 PM
03/04/24 01:12 PM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
I buy it as cart filler from Summit...If I need to get over the free shipping threshold, Type F, spark plugs ,etc...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: DoubleD]
#3218051
03/04/24 04:03 PM
03/04/24 04:03 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
FWIW I ran the ATI fluid prior to switching to Transynd in my Top Sportsman car
[Re: Al_Alguire]
#3218054
03/04/24 04:13 PM
03/04/24 04:13 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I run type F in 3 of my cars once they were new build transmissions. Still have Mercon in the others.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Mopar.70]
#3218079
03/04/24 05:50 PM
03/04/24 05:50 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
When I mentioned the B&M blue Stuff i was being sarcastic. Guess I should have put a smiley on there. Nobody I know has used that snake oil for about 50 years. If the TranSynd runs significantly cooler then that would be worth paying for. Does it affect stall speed, et or consistency? Curious on the negative on this one. So I was instructed to use a mineral F in my race 727 and ended up picking this stuff. Used it last season, no issues but being first year out with the car I only got about 25 passes in. But no shift problems and no heat issues. I have a gage on the trans, thought it didn't work until one night I went a few rounds and it registered on the gage but never over 160. In my street car I use the ATI 20w previosuly mentioned as well. This has been one of the things that has drove me crazy as of late since the stuff that was orignally spec'ed for these is no longer available. Not really a negative, more like a don't waste your money on the B&M. It is simply mineral type F with blue dye for a lot more money. I am sure it works as well as any other type F. Type F has been the go-to for decades until the synthetics showed up.
[Re: moparx]
#3218284
03/05/24 12:32 PM
03/05/24 12:32 PM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
Wow !! I should have checked on here first ! I clearly got ripped off by Advance at $9.79 a quart !!! I thought about trying ATI or another type fluid but my 904 has been in my mid 11 second Dart for 7 years now using type F without a problem . My trans builder built me a complete race ready spare 904 a few years ago , I haven't needed it ! So either the type F works well or I have a really good trans builder... I do !
[Re: moparx]
#3218391
03/05/24 05:27 PM
03/05/24 05:27 PM
Posts: 4,070 Mo.
racerx
Mo.
thanks all. a couple of days ago, i ordered 24 quarts from rock auto. with tax and shipping, along with the 5% discount coupon, it came out to $4.41 per quart. Which Brand fluid did you decide??
[Re: dvw]
#3218519
03/06/24 07:55 AM
03/06/24 07:55 AM
Posts: 4,070 Mo.
racerx
Mo.
If your not running a trans brake. If you have a reasonably sized cooler. If your trans was assembled with correct clearance. Then any fluid will work. Doug Doug, what brand would you recommend for a tranny that has a break/race clutches/aluminum drums that Rock auto sells?
[Re: racerx]
#3218534
03/06/24 09:49 AM
03/06/24 09:49 AM
Posts: 9,838 MI, usa
dvw
MI, usa
If your not running a trans brake. If you have a reasonably sized cooler. If your trans was assembled with correct clearance. Then any fluid will work. Doug Doug, what brand would you recommend for a tranny that has a break/race clutches/aluminum drums that Rock auto sells? I currently run JR1 synthetic. But in the past I’ve run Walmart Dexron with zero issues. Doug
[Re: dvw]
#3218545
03/06/24 10:41 AM
03/06/24 10:41 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If your not running a trans brake. If you have a reasonably sized cooler. If your trans was assembled with correct clearance. Then any fluid will work. Doug Doug, what brand would you recommend for a tranny that has a break/race clutches/aluminum drums that Rock auto sells? I currently run JR1 synthetic. But in the past I’ve run Walmart Dexron with zero issues. Doug I had an issue with a flaired out bolt hole for the pump on my powerglide case several years ago. It was bleeding through and engaging my servo and wiping out my band. I was running Walmart brand Dextron 3 at the time because it was so easy to get and boy did the smell of it give me trouble. It has a smell to it like burnt clutches and made trouble shooting it hard. That’s the main reason I went back to type F.
[Re: racerx]
#3218581
03/06/24 01:21 PM
03/06/24 01:21 PM
Posts: 19,408 north of coder
moparx
thanks all. a couple of days ago, i ordered 24 quarts from rock auto. with tax and shipping, along with the 5% discount coupon, it came out to $4.41 per quart. Which Brand fluid did you decide?? the cheapy, Max1.
