1969 hemi super bee scoops....
#3217194
03/01/24 02:42 AM
03/01/24 02:42 AM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I bought a pair of 69 hemi super bee scoops( aftermarket) that did not come with the Chrome bezels on them. After looking at the scoops. I see the intentions where they go. But ot sure how they Attach. Can some one explain or possible show pics of how they do attach to the scoops Also did they get hemi badges on the scoops ? T.ia.
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 1969 hemi super bee scoops....
[Re: toplescuda]
#3217240
03/01/24 12:08 PM
03/01/24 12:08 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I bought a pair of 69 hemi super bee scoops( aftermarket) that did not come with the Chrome bezels on them. After looking at the scoops. I see the intentions where they go. But ot sure how they Attach. Can some one explain or possible show pics of how they do attach to the scoops Also did they get hemi badges on the scoops ? T.ia. Chrome bezels should screw in from the front , phillips head screws , oval head I think , I have to look at my car. There should be 2 holes on the side that faces out that the engine callout badge goes into , it's the same scoop no matter what engine .
[Re: Jim_Lusk]
#3217278
03/01/24 01:46 PM
03/01/24 01:46 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Hard to tell. But they mount to these 2 studs in front? And I knew that they would also had 383 emblems These scoops don't have holes for engine call out but later I would like to put hemi emblems on them They are going on a ramcharger hood that will be getting a 5.7 swap
[Re: toplescuda]
#3217311
03/01/24 04:49 PM
03/01/24 04:49 PM
JohnRR
Hard to tell. But they mount to these 2 studs in front? And I knew that they would also had 383 emblems These scoops don't have holes for engine call out but later I would like to put hemi emblems on them They are going on a ramcharger hood that will be getting a 5.7 swap No they don't attach to the front studs , they go in the front and held on with 2 screws , one in each upper corner. If there are no holes they might be off an A body , 340 cars had them in 71 , maybe 70 , and I don't think they had engine call outs
[Re: JohnRR]
#3217361
03/01/24 08:29 PM
03/01/24 08:29 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Hard to tell. But they mount to these 2 studs in front? And I knew that they would also had 383 emblems These scoops don't have holes for engine call out but later I would like to put hemi emblems on them They are going on a ramcharger hood that will be getting a 5.7 swap No they don't attach to the front studs , they go in the front and held on with 3 screws , one in each upper corner. If there are no holes they might be off an A body , 340 cars had them in 71 , maybe 70 , and I don't think they had engine call outs
[Re: toplescuda]
#3217374
03/01/24 10:07 PM
03/01/24 10:07 PM
Posts: 20,766 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I think the bezels attach to the scoops with a metal capture type clip that the screws go into so they stay on tight. You'll need to buy the chrome bezels and make sure they fit the scoops since they are aftermarket parts, which can be hit or miss.
These scoops came on 70 340 Swingers and they did have both the chrome bezels and the 340 emblems. They were also available on 1971 340 demons as well.
[Re: toplescuda]
#3217566
03/02/24 08:44 PM
03/02/24 08:44 PM
JohnRR
Hard to tell. But they mount to these 2 studs in front? And I knew that they would also had 383 emblems These scoops don't have holes for engine call out but later I would like to put hemi emblems on them They are going on a ramcharger hood that will be getting a 5.7 swap No they don't attach to the front studs , they go in the front and held on with 2 screws , one in each upper corner. If there are no holes they might be off an A body , 340 cars had them in 71 , maybe 70 , and I don't think they had engine call outs I goofed the screw count , only 2 , one on each side into those tabs in front of the 2 forward posts.
[Re: JohnRR]
#3217622
03/03/24 03:45 AM
03/03/24 03:45 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Anyone have a nice clear upside down pic showings some detail of the bezel mounting? Thanks for all the replys
[Re: toplescuda]
#3217672
03/03/24 10:50 AM
03/03/24 10:50 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Anyone have a nice clear upside down pic showings some detail of the bezel mounting? Thanks for all the replys Yes it's a little fuzzy but if you zoom in on Jim Lusk's pic above you can see how the bezel fits and the holes for screws.
