Cleaning a fan clutch #3214481
02/18/24 10:22 PM
02/18/24 10:22 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I've got a fan and clutch that was original (as far as I know) to a 67 440 GTX that I want to use om my 470. The clutch is not loose and turns properly but the aluminum part is grimy and the front face has surface discoloration (sort of rusty in color but there is no actual scaly rust) so I need to clean it. Short of degreasing and then media blasting, is there a better way to clean it (some sort of cleaner/solvent) that will not damage it and leave an original looking finish?
Re: Cleaning a fan clutch [Re: 6PAX] #3214533
02/19/24 07:50 AM
02/19/24 07:50 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Soda blasting in a small blast cabinet works for me.
Re: Cleaning a fan clutch [Re: fastmark] #3214572
02/19/24 11:17 AM
02/19/24 11:17 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Hopefully it is not greasy from leaking. I cleaned mine up to only find out it was leaking at the shaft. Believe it or not I used spray starting fluid to clean most of it.
Re: Cleaning a fan clutch [Re: 6PAX] #3214608
02/19/24 01:33 PM
02/19/24 01:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There's no way to bench test a fan clutch. Chances are a 50+ year old clutch isn't worth the time/effort you'll invest in it.
Re: Cleaning a fan clutch [Re: John_Kunkel] #3214626
02/19/24 02:14 PM
02/19/24 02:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree And will advise against any type of media blasting as the media / dust may penetrate the seals twocents beer
Re: Cleaning a fan clutch [Re: TJP] #3216171
02/25/24 09:00 PM
02/25/24 09:00 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Try Simple Green
Plymouth Makes It!
Re: Cleaning a fan clutch [Re: 6PAX] #3216248
02/26/24 06:47 AM
02/26/24 06:47 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I would also believe that a new clutch with new seals would be worth the cost.
To “bench test” a clutch rotate it with a drill press or lathe (devise a guard too)
and check the rpms of both inner and outer body with an adjustable strobescope that has an rpm readout.
Obviously the cost of the test equipment is high compared to a new clutch,
but adjustable LED strobes cost way less today in inflation adjusted numbers than the 1980s when they used Xenon incandescent bulbs.
Re: Cleaning a fan clutch [Re: 360view] #3216327
02/26/24 01:12 PM
02/26/24 01:12 PM
moparx Online content
moparx  Online Content
i wonder how dawn "power wash" would work to clean the fan ?
you just spray it on, then rinse it off.
i have used it on lots of greasy parts, and it works pretty good.
however, i have not tried it on anything i was concerned about with a stenciled part number.
beer
