Re: Max wedge rocker arms
[Re: cudaman1969]
#3215896
02/24/24 06:28 PM
02/24/24 06:28 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It was about 675hp…….with the air filters on, and thru the ex manifolds…….crank driven water pump too.
[Re: fast68plymouth]
#3215911
02/24/24 08:12 PM
02/24/24 08:12 PM
Posts: 31,068 Oregon
AndyF
It was about 675hp…….with the air filters on, and thru the ex manifolds…….crank driven water pump too. That is pretty good power for that combination. My original 505 with Indy EZ heads and a cross ram only made 625 hp and that was with dyno headers. That engine had a Mopar Performance reproduction cross ram on it and it was a real cork. That same engine picked up 80 hp switching to an Indy box ram (peak of 705 hp), and it picked up 115 hp (peak of 740) with an Indy 440-3 intake and a Dominator. The same engine ended up making over 800 hp after switching to a roller cam. After that experience I stopped fooling around with cross rams and decided to stick with a modern single four barrel intake. http://www.moparts.org/Tech/Archive/bb/80inches.html
#3215932
02/24/24 09:55 PM
02/24/24 09:55 PM
Posts: 3,089 Michigan
A727Tflite
It was about 675hp…….with the air filters on, and thru the ex manifolds…….crank driven water pump too. With which heads...and how big?
[Re: stroked470]
#3216056
02/25/24 01:48 PM
02/25/24 01:48 PM
fast68plymouth
So. Burlington, Vt.
That looks even worse than I remember it.
Believe it or not, we actually did a cam change on the dyno………without pulling the intake. About 1/2 way thru the job we’d realized we should have pulled the manifold. But we finally got it back together.
[Re: stroked470]
#3216184
02/25/24 09:27 PM
02/25/24 09:27 PM
A727Tflite
They have been milled heads are 82cc. I know - I can tell, the valve covers have the manifold trapped.
