Battery charger, looking for recommendations #3215528
02/23/24 01:04 AM
02/23/24 01:04 AM
GMP440 Offline OP
GMP440  Offline OP
My 35 y/o Shauer Battery charger and boost starter finally gave out. Looking to buy a new battery charger. Asking members for recommendations on what they have. Thanks.
Re: Battery charger, looking for recommendations [Re: GMP440] #3215530
02/23/24 01:26 AM
02/23/24 01:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bought a Duralast charger from AutoZone a few years ago - has boost, fairly quick charge, and maintainer - and it's been great.
Can't recall what I paid, probably $60-$80 range. It's a couple inches larger in all dimensions than a large FSM.
Re: Battery charger, looking for recommendations [Re: topside] #3215539
02/23/24 07:48 AM
02/23/24 07:48 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I bought this one in 2020. I have used it to top off a battery for the car before it comes out of storage. I used a larger charger to bring back a totally dead one just enough to use this one. Lasted for a bit longer, but the car it was in never got driven so it ultimately died again. I wrote down somethings, but don't recall exactly what else happened. Battery is 800CCA but was 12.3 V, 563 CCA, resistance 5.54, life 46.5%, and 68% charge. Charged it for about 11 hours. 24 hours later it was 12.57 V, 616 CCA, 5.08 resistance, 56.4% lilfe, and 92% charge.
https://www.amazon.com/gp/product/B00Q3CM2QY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: Battery charger, looking for recommendations [Re: GMP440] #3215548
02/23/24 09:19 AM
02/23/24 09:19 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If I were getting a new 12 volt lead acid “boost” battery charger
I would get one with both volt meter and ampere meter,
although it is not too big a job to add an amp meter:
https://www.amazon.com/Battery-Charger-Clamp-Mount-Heavy-Duty-Chargers/dp/B07RYVKFZL
Also ponder if you want a stand alone battery test analyzer.
I bought a Konnwei KW681 at a thrift store because at $15 new in box I thought I would not be out much.
The KW681 doesn’t just offer one battery test,
it offers numerous
Euro, Japanese, German DIN, Canadian, USA and manufacturers association tests.
I have had for decades an “old school” analog meter MAC Model BT7300 6/12 volt 130 amp load tester
I have liked this LED display only maintainer that outputs 4 amps max
but it recently misdiagnosed
a SLA 12 volt battery for “child play car”
and led to an hour’s wasted time troubleshooting the switches of the toy car.
https://www.amazon.com/Pulsetech-Xt...8-1&keywords=desulfating+charger#Ask
Re: Battery charger, looking for recommendations [Re: 360view] #3215559
02/23/24 10:23 AM
02/23/24 10:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am assuming that your charger is the old school "hook it up and give it hell" style. Other than the transformer, ammeter, circuit breaker, and rectifier, there really isn't much to go wrong with one. I just rebuilt an old non-boost charger with a new rectifier and ammeter for under $30.
Why, because I hate these new "smart" chargers. Battery voltage too low, won't work. Decides when the battery is fully charged and most of the time it's not. Want a power supply to test motors like wiper and blower, won't with these.
No, sometimes technology is not our friend.
Re: Battery charger, looking for recommendations [Re: GMP440] #3215565
02/23/24 10:32 AM
02/23/24 10:32 AM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
I think a friend of mine years ago used a battery tender brand for his valiant. drive
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Battery charger, looking for recommendations [Re: rdrnr6970] #3215588
02/23/24 12:15 PM
02/23/24 12:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Battery Tender models have served me well for all of my non Optima batteries.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Battery charger, looking for recommendations [Re: BloFish] #3215591
02/23/24 12:28 PM
02/23/24 12:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Battery charger, looking for recommendations [Re: topside] #3215615
02/23/24 02:14 PM
02/23/24 02:14 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
That’s what I got 6-7 years ago. Does agm. Been a good one. Shows volts and also percent charged.
I want my fair share
Re: Battery charger, looking for recommendations [Re: SomeCarGuy] #3215633
02/23/24 03:25 PM
02/23/24 03:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Battery charger, looking for recommendations [Re: stumpy] #3215830
02/24/24 01:19 PM
02/24/24 01:19 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Schumacher. A great product which has been around forever.
Re: Battery charger, looking for recommendations [Re: Kudakidd] #3215870
02/24/24 04:13 PM
02/24/24 04:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I haven't found a Schumacher charger that will charge a nearly no voltage battery (with below 5v - 6v in it) without connecting a good or 12.4+v battery to the low volt battery. The Optima and some others will charge on their own regardless of the amount of voltage of the battery you are attempting to recharge. I have a motorcycle battery charger (KTM) that works even on the deadest car battery every time and it will also diagnose the condition of the battery and the entire charging system and if you have the leads backwards. It does AGM, Gel, Flooded and lithium Ion batteries. Had a Die Hard AGM battery out of the wife's Town & Country on a top-of-the-line Schumacher charger the week before last and it wouldn't even budge the 5 volts for several days. So I pulled and topped off another battery to 12.7v and connected it to the T&C dead Die Hard with 1-gauge jumpers and tried again with the Schumacher and got it up to about 8v and that was all with another week's worth of charging in the warm, heated basement shop. Put the KTM Fronius Acctiva Easy 1202 charger on it by itself and in less that a day it was at 12.7 volts and done. Not saying to get a KTM charger but do the search and see if the Optima or similar brand has the same features as the KTM charger. I now only use the Schumacher on a slightly low charged battery kind of like a maintainer and that's very seldom. In hindsight the Schumacher charger was a waste of money.
Check out the features and compare them to Optima and other similar chargers, then decide, click here Fronius Acctiva compact Professional charger
Look for these functions and technologies on other brands then decide.
Functions:
Acctiva Easy
- Suitable for charging and for charge conservation of all lead starter batteries
- Test function for starting capability and generator function
- Charging of deep-discharged batteries possible
- Charging status indicated by segments on display
- 100% safety for vehicle, vehicle electronics and battery
- Compact design and easy connection
Technology:
Active Inverter
- Compact dimensions and low weight for flexible application options
- Optimised charging process for maximum energy efficiency and lower energy costs
- Conservation charging minimises the risk of self discharge, even during longer periods of non-use
- High performance: optimal use of battery capacity
Re: Battery charger, looking for recommendations [Re: A12] #3216037
02/25/24 01:01 PM
02/25/24 01:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I went cheapie, and got this one from walmart a few years ago. I use it alot as a trickle 2amp charger and it's been reliable.
Facts are stubborn things.
Re: Battery charger, looking for recommendations [Re: A12] #3216063
02/25/24 02:04 PM
02/25/24 02:04 PM
East Bay, N. Cal.
calmopar Online sleepy
calmopar  Online Sleepy
East Bay, N. Cal.
I have had the same problem. Would have to start with a dumb trickle charger then switch to the Schumacher (which picked up and did a fine job). Pain in the butt, though.
Trying to enjoy life!
Re: Battery charger, looking for recommendations [Re: calmopar] #3216073
02/25/24 02:25 PM
02/25/24 02:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yes that's what I also hate about the Schumacher or similar types that will not charge when a battery is deeply discharged. I wonder how many people have replaced a battery after trying to charge it and that doesn't work even on a charger for days?
If I go looking for another charger in the future it will have the "will charge deep discharged batteries" feature.
Re: Battery charger, looking for recommendations [Re: A12] #3216078
02/25/24 02:40 PM
02/25/24 02:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Charging a 19 year old deeply discharged battery shock
The presenter states that an AGM charging feature battery charger will work on a deep dischared battery (-10v) but my Schumacher charger with AGM, GEL and standard lead flooded capabilities WOULD NOT CHARGE my Diehard AGM even with one good 13v battery and 1-gauge jumpers. Go figure?
Re: Battery charger, looking for recommendations [Re: A12] #3216739
02/28/24 12:23 AM
02/28/24 12:23 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
I bought a "newer" charger from NAPA a few years back and splurged on the mid-grade model at like $120 on sale. Like others have pointed out, won't charge a dead battery and doesn't seem to fully charge any battery. I've started buying Schumaker(?) or older Craftsman automatic chargers at yard/estate sales lately. At $10-$15 each I can have a lot of spares that actually work like I need them to. 1 in the garage, 1 in the barn, 1 in the garden shed for the mowers...you get the idea.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
