Pitman arm install #3216039
02/25/24 01:05 PM
02/25/24 01:05 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm working on installing my new pitman arm on my 69 Dart. I'm using 73 Duster steering linkage and my car's original power steering box. Per things I've read, because the 69 power steering box shaft is smaller than the 73-up shaft, I had to get a 73-up manual steering pitman arm to fit both the 69 box shaft and the 73 center link which I did (Mevotech brand). My service manual says the torque spec is 120 ft. lbs. on the nut. So. I have it torqued to that but the nut doesn't look to me like it is on far enough. It is basically flush with the end of the shaft. I looked on my 70 Dart to compare and the shaft on it sticks out beyond the nut about 1/4". Your thoughts please.
Re: Pitman arm install [Re: 6PAX] #3216045
02/25/24 01:23 PM
02/25/24 01:23 PM
IMGTX Offline
IMGTX  Offline
If you achieved proper torque that is a good sign and it is probably fine.
BUT
1. Make sure the arm isn't binding against the box. It should not rub when you turn the wheel. There should be a gap between the arm and steering box/seal.
2. I would also suggest you remove the nut and make sure that the nut/washer isn't binding on the splines before it clamps the arm into the splines. After removing the nut you will not be able to simply remove the arm. It should take a puller and a little force.
If the arm isn't binding and the nut is applying all that force to the shaft/arm spline mating you are good.
Re: Pitman arm install [Re: IMGTX] #3216076
02/25/24 02:33 PM
02/25/24 02:33 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Here is a pic of it. The gap between the arm and the box is 5/8". I don't know if this would have anything to do with it or not but the 69 service manual calls for 120 ft. lbs. torque and the 73 manual calls for 175 (or 170) I believe. I went with the 120 because the box is a 69 unit.
Re: Pitman arm install [Re: 6PAX] #3216086
02/25/24 03:20 PM
02/25/24 03:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It almost looks like you missed spline key slot.
Re: Pitman arm install [Re: stumpy] #3216109
02/25/24 04:12 PM
02/25/24 04:12 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
No, it's lined up on the splines correctly. I was able to push it on by hand some before I started using the torque wrench.
Re: Pitman arm install [Re: 6PAX] #3216128
02/25/24 05:33 PM
02/25/24 05:33 PM
IMGTX Offline
IMGTX  Offline
That is a bigger gap than I am used to seeing on a mopar but it could be the new pitman arm is narrower inside than the old.
Do you have the old one to compare it to?
If so you could remove and compare the parts inside diameter with a caliper.
If the splines are correct and engaged. The nut is tight and all the threads of the nut are used.
You should be fine.
I agree though, it looks wierd.
Re: Pitman arm install [Re: IMGTX] #3216235
02/26/24 01:16 AM
02/26/24 01:16 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Maybe take nut off and tap the arm on a little with a brass hammer? Does it look like it’s in alignment/free movement with the center link?
I want my fair share
Re: Pitman arm install [Re: SomeCarGuy] #3216258
02/26/24 08:12 AM
02/26/24 08:12 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Yes, it all moves like it should. I had it all centered when I started tightening the nut but the pitman arm turned to full lock (as shown in the pic) while I was tightening it.
Re: Pitman arm install [Re: 6PAX] #3216289
02/26/24 10:53 AM
02/26/24 10:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the bottom of the pitman arm flush with the splined shaft ? How's the angle of the centerlink , does it seem parallel under the pan ?
Re: Pitman arm install [Re: JohnRR] #3216294
02/26/24 11:05 AM
02/26/24 11:05 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
A little moly lube on the splines couldn't hurt anything either.
Re: Pitman arm install [Re: John Brown] #3216330
02/26/24 01:15 PM
02/26/24 01:15 PM
moparx Offline
moparx  Offline
i like to use anti-seize.
beer
Re: Pitman arm install [Re: moparx] #3216492
02/26/24 11:25 PM
02/26/24 11:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
With the quality of todays parts I might suggest removing the arm and checking /verifying the spline engagement AND taper with Prussian blue or Dykem twocents beer keep us posted
Re: Pitman arm install [Re: TJP] #3216532
02/27/24 08:39 AM
02/27/24 08:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Looks pretty much right to me. If the splines came through, the nut would tighten to the splines and not the bottom of the arm. All the ones I have worked on the nut was pretty much flush with the end of the threads when installed.
Re: Pitman arm install [Re: TJP] #3216582
02/27/24 12:42 PM
02/27/24 12:42 PM
moparx Offline
moparx  Offline
this is a good idea, siting the "quality" [or lack thereof] of parts today.
beer
Re: Pitman arm install [Re: moparx] #3217506
03/02/24 03:42 PM
03/02/24 03:42 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Update. I took the pitman arm off today. I measured the overall length of the steering box shaft (2 1/8"), the length of the splined part of the shaft (1 1/8"), the length of the threaded part (1") and the width of the pitman arm body (7/8"). I also measured the length of the threads that were exposed (5/8") after I took the nut and washer off but before I pulled the arm back off. After calculating everything, I'm coming up with only 1/2" of spline engagement when the arm was installed and torqued to spec. These are the calculations I used:
2 1/8" (overall length of shaft) - 5/8" (exposed threads with arm in place) - 7/8" (width of arm body) = 5/8" (unused splines at top of shaft)
then
1 1/8" (length of splined part of shaft) - 5/8" (unused splines at top of shaft) = 1/2" (of splines covered by arm when in place)
Should be more than 1/2" engagement, shouldn't it?
Re: Pitman arm install [Re: 6PAX] #3217508
03/02/24 04:09 PM
03/02/24 04:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I wouldn't trust just a 1/2". Can you see why the arm won't go further on?
Re: Pitman arm install [Re: stumpy] #3217513
03/02/24 04:33 PM
03/02/24 04:33 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I don't see anything unusual. The splines on both the box and the arm look fine to me. I torqued it to the 1969 factory spec of 120 ft. lbs. because I'm using the original 69 steering box. But, being it is a 73-up style arm, I wonder if I should use the 73 spec. which I think is 170 lbs.? Just don't want to cause any damage to the steering box.
Re: Pitman arm install [Re: 6PAX] #3217520
03/02/24 05:19 PM
03/02/24 05:19 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Here is a non-OEM setup, Borgeson specifically, but for what it's worth it shows the level at which the nut finished with a fair bit of room between the pitman arm and the box housing itself - which in this install is covered with a dust shield.
FYI - HERE is my thread on the pitman arm nut torque for that Borgeson install, for what it's worth.
Re: Pitman arm install [Re: Diplomat360] #3217637
03/03/24 09:10 AM
03/03/24 09:10 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
How did the original arm fit? Was it the same way?
Re: Pitman arm install [Re: mopars4ever] #3217650
03/03/24 09:52 AM
03/03/24 09:52 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The original arm fit fine but it was the 69 style arm, not the 73-later type I bought to match the 73-later steering linkage I am using.
