Greasing steering linkage #3215789
02/24/24 11:43 AM
02/24/24 11:43 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
When greasing the steering linkage components with the grease gun, should you pump the grease in before or after tightening up the pivot nuts?
Re: Greasing steering linkage [Re: 6PAX] #3215794
02/24/24 11:51 AM
02/24/24 11:51 AM
md
mopars4ever Offline
mopars4ever  Offline
md
After tightening IMO, if before it may just squeeze the excess out anyhow. Also I do not pop the grease out of the boots. Just till I see it fill the boot some.
Re: Greasing steering linkage [Re: mopars4ever] #3215797
02/24/24 12:00 PM
02/24/24 12:00 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
That's what I thought. Just wanted to be sure. Thanks.
Re: Greasing steering linkage [Re: 6PAX] #3215843
02/24/24 02:22 PM
02/24/24 02:22 PM
IMGTX Offline
IMGTX  Offline
What mopars4ever said....
Plus if you ever get a new part with no place to grease it, remove the boot and pack the joint with grease. It is very common for many new parts to be non-greasable and they don't put enough, or sometimes any, grease in the joint.
