Re: Snowblower storage question
[Re: MI_Custumz]
#3214209
02/17/24 06:53 PM
02/17/24 06:53 PM
Posts: 25 Verrrrry South Jersey
SpeedThrills
Could be the tire is dry rotted and is leaking through the sidewall, then the bead let go. I saw it all the time when I was repairing that kind of stuff. I used to put inner tubes in for customers. Easier than constantly filling a tire with a leaking sidewall, and cheaper than new tires.
Edit: I wouldn't worry about propping it up.
[Re: SpeedThrills]
#3214220
02/17/24 07:30 PM
02/17/24 07:30 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
i live in Milwaukee Wisconsin area. so i usually do need a snow blower about 5 times a year. used it 1 time this year.. for the last 15 years when i store my snow blower i do only 1 thing to it for storage. i installed a shut off valve for the gas. i turn off the gas to the carb and then start it. run it until it dies so there is no gas in the carb. i leave the gas in the tank, it's usually about 1/2-3/4 full. . put a cover over it and don't touch it until next year. new year about the end of October. i check the tires to see if they are up to pressure. top off the tank with fresh gas. turn on the valve to the carb and start it. i have a craftsman blower with a 9hp motor with what they call power steering. it's about 20yo. still on original tires. i did change the belts at about the 10 year mark of my ownership. still worked just fine. i also changed the friction drive wheels that power the wheels. they were starting to slip. i also make sure i have extra shear pins, 1/4"X 1" regular bolts with nylock nuts, for the augers that turn the snow into the blower part. i usually break 1 or 2 a year.
perception is 90% of reality
[Re: A12]
#3214279
02/18/24 05:56 AM
02/18/24 05:56 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I have a 20 year old MTD 10hp that has had flat tires for nearly its entire life. I get as good a traction as I probably would with chains.
[Re: 6PakBee]
#3214285
02/18/24 07:57 AM
02/18/24 07:57 AM
Posts: 5,647 Port Huron, Michigan
MI_Custumz
I've had the snowblower since 2008 or 2009 and this is the first year I had a tire issue. The tire that broke the bead was in good shape, just broke the bead. The other one was real low, but looked good and felt good when I pushed on it. I'll park it as is this year and check the tire pressure once in a while. I think the tires just got low with the temperature change and I neglected to look at the psi and went by feel.
[Re: MI_Custumz]
#3214457
02/18/24 09:10 PM
02/18/24 09:10 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I've never had a tire on a snowblower go flat sitting in the off season that I can remember. My current Toro is 16 years old and I don't think I've ever added air to the tires.
Now wheelbarrows, that's a different story, I just finally bought a solid tire for it because I'm tired of dealing with a flat.
[Re: JohnRR]
#3214476
02/18/24 10:09 PM
02/18/24 10:09 PM
6PakBee
North Dakota
Now wheelbarrows, that's a different story, I just finally bought a solid tire for it because I'm tired of dealing with a flat. I did that two years ago and went back to a pneumatic tire when the solid tire came off the rim.
