Page 6 of 7 1 2 3 4 5 6 7
Re: '14 JKU M-380 - "Kilroy" [Re: Fat_Mike] #3277740
12/23/24 11:27 AM
12/23/24 11:27 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
thumbs
exhaust is basically in, charcoal canister and air tank are mounted, including a heat shield. Brake lines and full hydro hoses are on deck.
...biggest air tank I could reasonably fit was this aluminum 4-gallon unit -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
52 Willys M-38 "Poncho"
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3277891
12/24/24 08:13 AM
12/24/24 08:13 AM
BDW Offline
BDW  Offline
Nice work!
Gonna be a shame to cover it all up
Re: '14 JKU M-380 - "Kilroy" [Re: BDW] #3278833
12/29/24 01:28 PM
12/29/24 01:28 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
naw it's cool smirk
Brake lines are in place, and now working on the full hydro steering hoses n stuff, and I was able to re-purpose the heat shield I had in the Dakota - looks like it'll work great -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3279073
12/30/24 01:13 PM
12/30/24 01:13 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...soooo when I made the y-pipe I neglected to remember to include the O2 sensor bung...so I had the pleasure of drilling a big hole through the beautiful plumbing to weld in the bung, which worked fine - meh no biggie -
Gas tank plumbing. Since it hadn't yet broken I took the opportunity to reinforced the vent port - took a piece of 3/16 brake line, sanded it just a skosh thinner, lubed it up with JB Wend, stuck it in, and used a dremel wheel to cut it flush -
Wanted to use the OE "5/16" fitting that goes onto that port and eliminated the excess 'baggage' from it, used JB-weld seal it off, and now it is a typical 5/16 fitting - this is the tank vent to the charcoal canister -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3279077
12/30/24 01:15 PM
12/30/24 01:15 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Next, in order to figure out the fuel filler tube I first had to modify the filler neck mount. The OE plastic tabs were brittle and broken, so I am using screws to retain it to the body...but naturally there wasn't enough meat behind it so I fabbed an 'extension' from 16g steel to give the screws more purchase, making the filler neck mount much more secure -
...and with that located in place I can finish the filler neck...and I'll begin the work to secure the Poison Spyder corner armor in place...which is what drove all the filler neck work to begin with... -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3279311
12/31/24 12:03 PM
12/31/24 12:03 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
Welded a flange to the filler neck so that instead of simply 'floating' in a grommet it now screws firmly in place. Also, removed the tiny vent tube and welded in a bung for a 1/2 NPT x 5/8" hose for the tank vent. It aught to filler up as fast as the hose can pump it out now (y)
Got the filler hose and vent hose figured out - used two hoses from Oriellys to connect the 1" and 1"/1.25" tubes (#FNH111 and 118) - works awesome, and WAY cheaper than what the dealer wants for those two hoses.
Added a small tab to support the other end - now it bolts up nice n tight to the body and won't rub against the bump stop and shock tower -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3280208
01/03/25 12:34 PM
01/03/25 12:34 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...so I want to start running wires...but before I can do that I need a place for the battery to sit...and for that I need something for the battery to sit on. Being a right-hand-drive setup originally I had to alter things in the engine bay anyway, and I did find the correct left-hand-drive inner fenders, but when I started to ponder where the steering reservoir and battery and all the under hood stuff would go...well the OE inner fenders just weren't gonna cut it...SO...out with the cardboard, 14g steel sheet, and jigsaw, and I now have fresh inner fenders, and everything should 'fit' way more nicer'er thumbs
Still a lot of finish work, but for now it's great for mockup. The d-side was the first to be cut/demo which is why it is less 'complete' than the p-side - it'll ultimately look just like the p-side. Both inner fenders are also going to be part of the lower extensions, which I'll complete later on. Forward progress thumbs
before -
...aaaaand after - nice clean slate -
before cutting and breaking -
my group 27 battery is almost exactly the same size as our 50-cal ammo can/1st aid kit - gonna fit perfect -
...going with an X2 Power dual purpose AGM battery
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3281481
01/08/25 04:10 PM
01/08/25 04:10 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
so I have a nutzert tool and a bunch of nutzerts...but they don't have a ton of 'capture' on the back side of a panel, and found these 'HD' rivet nuts to secure the tops of the inner fenders - these mushroom out in back a lot more than nutzerts and 'capture' much more of the backside of a panel, which in my case I think is a plus; had to modify the tool to get further into these than the nutzerts but seems to work fine -
they appear to be a lot more hooah than the smaller style nutzerts (I'll use these on the rear quarter panels for the corner armor too) -
Lots of 'fine tuning' going on with the inner fenders, including the brake flex lines from the master cylinder to the junction block on the frame.  While I was working on that I copied an idea I used helping a friend work on his M37 project and made a small bracket to attach the pro valve - now everything is nice and tidy and easy to get to -
One minor correction to the rear flex hose and the brake systems will be ready to bolt in for good.
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3282441
01/13/25 10:22 AM
01/13/25 10:22 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
the inner fenders need some support along the inside edge, and I'll eventually have fender liners to protect the engine and such from splash and debris, so I made the center section of the fender liners which serve as support for the inner fenders - makes everything good n strong especially the p-side to support the 65lb battery - should work great. I'll complete the fender liners after it's running...
bolts to the shock tower -
and to the inner fenders -
and sitting on a megaware battery guard (gel mat) the battery mounts are essentially done - like everything else ready for final welding and paint -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3282584
01/14/25 06:01 AM
01/14/25 06:01 AM
BDW Offline
BDW  Offline
Those bigger nutserts look beefy.
Do you need a hydraulic crimper to set them?
Re: '14 JKU M-380 - "Kilroy" [Re: BDW] #3282617
01/14/25 10:53 AM
01/14/25 10:53 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
I think they will have better 'retaining power' than the typical nutzerts, but potentially less 'counter-rotating' power - meaning they might spin if over-cranked etc., so I am planning to tack weld the sides of every one of them for good measure. The tool I have is just the typical nutzert tool, which I had to modify the chuck to let it thread deeper into the longer rivet nuts for more thread capture
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283218
01/17/25 12:48 PM
01/17/25 12:48 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...needed a decently big coolant overflow/recovery tank and wanted to reuse the one I had in the Dakota...which is from an XJ...but anyway made a small pocket in the inner fender to allow it to fit under the hood (where the square is) -
now you don't see it...
...now ya do -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283219
01/17/25 12:48 PM
01/17/25 12:48 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...now ya do -
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283585
01/19/25 11:50 AM
01/19/25 11:50 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
ok - 2.5" front frame chop done, trimmed the front bumper to get it and the winch as close to the grille as possible (without modifying the grille) -
chopped out the crash bar, and welded in a mount for the 20" 8an (1/2") dual-pass power steering cooler -
shouldn't put very much 'heat' into the radiator...which was my primary concern -
and finally got to pull the trigger on a fun mod - since I'm doing open cowl surgery anyway (to swap the RHD wipers and linkage to LHD)...well there's an excellent spot right there just beggin' to be used for better things, so I'm putting my air intake in there, way up high and as cool as reasonably possible - it'll have a short/stubby M-35 style snorkel built into the cover panel - should work great. The intake tube will be welded into the firewall, and with polyurethane engine mounts there shouldn't be much wiggle placed on it, and the silicone coupler will absorb any leftovers -
[img]https://i.imgur.com/K9T8qxs.jpg[/img]
and with the power steering cooler in place I think I may actually have all of the critical systems mapped out...and after a very thorough (and long overdue) shop cleanup I'll pull the body back off for the firewall and other final mods, and...I think...I'll be ready to slap on some Rustoleum Rusty Metal Primer and Air Force Blue on the engine pay panels...and then (gasp) be ready to assemble this thing for reals.
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283735
01/20/25 11:32 AM
01/20/25 11:32 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...it's been a year since I started wrenchin' on the Jeep...and I'm happy to say it's going great and I'm staying motivated. The first stage was 'figuring things out' and just getting enough hardware in place (like figuring out how to make all the driveline fit, etc). Stage two was getting things to actually connect to each other (t-case linkage, pedals, reservoirs, panels/brackets, etc), and now the final stage is getting things wet, laying in the wiring, and getting it running/driving. As I'm getting ready to make the final push I first need to clean my room...and this morning I actually found the surface of my workbench!...
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283854
01/20/25 09:00 PM
01/20/25 09:00 PM
BDW Offline
BDW  Offline
Domino's ???!!!
No Little Caesar's around smile
Re: '14 JKU M-380 - "Kilroy" [Re: BDW] #3283919
01/21/25 10:30 AM
01/21/25 10:30 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...oh Domino's by far laugh2
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3283928
01/21/25 11:23 AM
01/21/25 11:23 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Forget the pizza! I was thinking I need to send you a new tape measure for a belated Christmas present.
Re: '14 JKU M-380 - "Kilroy" [Re: Fat_Mike] #3284095
01/21/25 07:07 PM
01/21/25 07:07 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
oh no worries there - I've been cutting old broken ones into very usable sections for years...but thanks thumbs
Re: '14 JKU M-380 - "Kilroy" [Re: Mad-Max] #3284130
01/21/25 09:25 PM
01/21/25 09:25 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I'd never seen a broken tape measure being of any use prior to that pic, but I get it now. up
