'Fresh' '69 340; $5,000
#3213905
02/16/24 10:46 AM
02/16/24 10:46 AM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
' Selling my original 340 from my 69 Dart. It was completely rebuilt by Hughes Engines several years ago. Has been sitting ever since, never fired. 1969 block .020 over Everything is new inside. I have all the paperwork from the rebuild. Around 10.5:1 compression X heads with 2.02/1.62 valves Hughes hyd cam 0.536/.0540 Hughes adjustable rocker arms and push rods ARP fasteners Milodon oil pan Edelbrock Torker II intake'www.facebook.com/marketplace/item/329514820065067
Master, again and still
Re: 'Fresh' '69 340; $5,000
[Re: not_a_charger]
#3213930
02/16/24 12:56 PM
02/16/24 12:56 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Those pistons look cleaned up used. I can see carbon in valve pocket corners
I assume and hope Hughes didn't paint that. Wonder if they just assembled the long block or just machining?
