Gas tank filler neck 67 cuda #3213676
02/15/24 09:52 AM
02/15/24 09:52 AM
CA
David Lee Offline OP
CA
working on 67 notch, the filler neck is missing. will the neck from a dart work?
thanks
Ah...so many pedestrians, so little time...
Re: Gas tank filler neck 67 cuda [Re: David Lee] #3213732
02/15/24 01:36 PM
02/15/24 01:36 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi David , Factory Parts Book 1967 , 1968 , 1969 Section 14-86-40 shows Valiant , Dart , Barracuda uses filler Tube Part # 2800 906 , drive unless it's a Barracuda Special 2Dr HT FastBack , then it's part # 2800 914 . bump
Re: Gas tank filler neck 67 cuda [Re: 1969ronnie] #3213734
02/15/24 01:44 PM
02/15/24 01:44 PM
CA
CA
thank you so much. now i can order one
