Re: Tie rod install questiion
[Re: stumpy]
#3213701
02/15/24 11:15 AM
02/15/24 11:15 AM
Posts: 215 Findlay
Ramman
Findlay
On a BIG piece of paper, where you keep the keys for that car, write "TIE RODS NOT TIGHT". Easy to forget things when your chest deep in a build.
[Re: Ramman]
#3213715
02/15/24 12:24 PM
02/15/24 12:24 PM
Posts: 5,613 Detroit area
6PAX
Detroit area
On a BIG piece of paper, where you keep the keys for that car, write "TIE RODS NOT TIGHT". Easy to forget things when your chest deep in a build. Yes, I know what you mean. My memory is not the greatest anymore anyway. I already have a list going of other things I've only finger tightened until I'm sure everything is right.
[Re: 6PAX]
#3213744
02/15/24 02:11 PM
02/15/24 02:11 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I can't say as I don't have the steering column installed yet. I plan on installing it next and checking to be sure it lines up before I tighten everything up on the steering linkage. I assume you centered the steering box ?
