Page 4 of 5 1 2 3 4 5
Powerglide parts [Re: bremotorsports] #3213181
02/13/24 10:08 AM
02/13/24 10:08 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Some leftover items from a upgrade. These items ALL have only a handfull of passes (only one tbrake pass)...
1)PG case cut for ultrabell will include 2-piece shield and tailshaft $250 or with GM bell (JW) $400
2)BTE straight cut 1.98 2 year warranty @ 1200hp $750
3)Coan PG turbo spline dual ring shaft @ 1000hp $125
4)Misc dual ring servo and cover with spring25$, flexible braided dipstick tube25$, Coan billet clutch hub30$ 6 bolt JW flex and adapters
I can make a package deal on these items plus other misc. for a 1000hp glide foundation.
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3213292
02/13/24 07:32 PM
02/13/24 07:32 PM
Locomotion Offline
Locomotion  Offline
MAIN BEARINGS
Speed Pro 120 M Std. - 360 Main Bearings (¾ groove) - (2 available) - $55.00/ea. set
Speed Pro 120 M 10 - 360 Main Bearings (¾ groove) - $55.00/ea. set
Clevite - MS1051P 10 – 360 Main Bearings (½ groove) - $70.00/ea. set
ROD BEARINGS -
Sealed Power/Federal Mogul 8-2130CP .030 rod bearings (not in original box) - $35,00/set of 8
Sealed Power/Federal Mogul 8-2130CP .030 rod bearings - $40.00/set of 8
Sealed Power/Federal Mogul 8-2130CP .020 rod bearings - $45.00/set of 8
PISTON RINGS -
Childs & Albert RS-10477 – 25 4.025 5/64 file fit low tension oil rings - $80.00 set
Childs & Albert RS-10477 – 45 4.045 5/64 file fit low tension oil rings - $80.00 set
Hastings 2M 5505 035 – 4.035 1/16 file-fit low tension oil rings - $70.00 set
TIMING CHAINS -
Cloyes True Roller 9-3103 Timing Chain Set - $50,00/set *****SALE PENDING*****
Cloyes True Roller 9-3103-5 (.005 short) Timing Chain Set – $70.00/set
Cloyes 9-135 Std. replacement True Roller timing chain only - (2 available) - $45.00 ea.
Cloyes 9-135-5 (.005 short) replacement True Roller timing chain only - (2 available) - $55.00 ea.
MISC. -
Ross 984-01-25 Wrist Pins, Type 1, .984 in. Diameter, 2.500 in. Length, .150 in. Wall, 125 Grams - $100.00/set of 8
Eagle 12055 3/8" SIR rod bolts (also fits several Chevy, Ford, 3/8" SIR rods) - (2 available) - $100.00 ea. set
All prices + shipping.
Shipped from Florida 32117
locomo@bellsouth.net
Sorry, no PayPal.
USPS money orders welcome.
Mopar to PG [Re: Locomotion] #3213660
02/15/24 08:21 AM
02/15/24 08:21 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
6 bolt Mopar to GM bell PG flywheel 130 tooth NEW $200
572 or 540 pistons [Re: HardcoreB] #3214324
02/18/24 12:03 PM
02/18/24 12:03 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Ross pistons for a 572" (4.505borex4.5stroke with a 7.1rod) but can be used for a 540" (4.250strokex6.535rod) They are flat top with a nice valve relief for a typical .800" lift cam and 2.25" intake. They are NEW. For standard type "440-1 heads". Pics to follow $600.
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3214355
02/18/24 02:23 PM
02/18/24 02:23 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Used Edelbrock 2920 Victor W-2 "Square Port" Intake for SB Mopar. Threaded holes in good shape, includes water lines, water outlet and cool MOON temp gauge that Doesn't work.
$250 + the ride
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3214394
02/18/24 04:48 PM
02/18/24 04:48 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Used Ladder bar Brackets (4) $15
Used adjustable shock brackets $25
Used Low rise aluminum Velocity stack $20 *********SOLD************
Used Mopar 8-3/4" yoke for 7260 U-joint, fine spline 29, threading good $25
Used Mopar 8-3/4" yoke for 7290 U-joint, fine spline 29, threaded holes good. $35
New TCI 5.0 band apply lever 727 & 904 $20
(2) used Transdapt remote oil filter mount with (2) #10AN fittings. Sorry, both are for GM 13/16" nipple . $25 each
All parts plus shipping. More pix available of individual items.
PM or email GTX5877@yahoo.com.
1974 VW Karman-Ghia
New Cope Manual Reverse Valve body and Turbo Action shifter [Re: moparts] #3215011
02/20/24 08:42 PM
02/20/24 08:42 PM
blewbyu Offline
blewbyu  Offline
All items brand new never installed and it is the low band apply $1100.00 new. Will sell for $900.00 plus shipping. May seperate but prefer to sell as a package. blewbyu2bad@aol.com
SOLD 383 Weiand Tunnel Ram w (2) 4224 Center Squirters [Re: Rocket] #3215562
02/23/24 10:28 AM
02/23/24 10:28 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Nice Vintage Tunnel Ram for 383-400 with pair of matched 4224 center squirters.
appears uncut original.
Also comes with linkage and fuel line as pictured.
Ran it a few years back on a run-in stand and all worked well.
SOLD
can deliver to Indy.
Chris
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3216024
02/25/24 12:22 PM
02/25/24 12:22 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Retirement sale continues: Have several small parts:
Set of 16 Titanium 10 degree valve spring retainers. 1.44" OD x 1.067" step x .705" inner step for dual or single spring $50 for set
340 Dampner with timing tape, cast #3614369 $25
C & S Specialties ultra light alcohol fuel filter, plastic with stainless screen, cleanable. $25
Mopar 8-3/4 or Dana 60 axle retainers for "Green" type ball bearings 2 pair $10/pair
Traction bar square u-bolts for in front or behind rear axle $5
NEW Victor JV605 for 360, which is misboxed, should be JV606 for 318-340 $8
All parts plus shipping from 56007
1974 VW Karman-Ghia
Re: For Sale - Race Parts - 1st Quarter [Re: GTX5877] #3216028
02/25/24 12:40 PM
02/25/24 12:40 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
MORE ITEMS:
Mr Gasket #6230 radiator hose T-Clamps. NEW in the package. Discontinued from MrG. $15 ***********SOLD********
NEW Speed- Pro R9278-35 file fit rings for 440 +.030, 4.350" bore, low tension oil, 1/16 x 1/16 x 3/16". New price today is $140, will take $60! ********SOLD***********
Melling K-63 Big block oil pump repair kit less pump gears. Has bypass springs and valve + gaskets $5
Hemi lash caps are *********SOLD***********
NEW Moroso 85820 U-Joint Girdles for 8-3/4 with 7290 yoke $25
All items plus shipping
1974 VW Karman-Ghia
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3217057
02/29/24 02:06 PM
02/29/24 02:06 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Spectre 432 Exhaust Collector Gaskets 3 1/2 $9.00 mailed US
432 gasket.jpg (1776 downloads)
Re: For Sale - Race Parts - 1st Quarter [Re: mopars4ever] #3217318
03/01/24 05:14 PM
03/01/24 05:14 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Weber Front Drive distributor mount with MSD adapter ring. Paid $190 delivered last fall. Sell for $125. New never used
Weber Plate.jpg (1645 downloads)
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3217532
03/02/24 06:03 PM
03/02/24 06:03 PM
York,Pa
Slap Shot Offline
Slap Shot  Offline
York,Pa
Not parting out or splitting engine or trans.
$25,500 picked up in York,Pa 17408
484 Hemi and trans specs
no carburetor
484 Street Hemi
Mopar block cast number 2468330-M
Pre-"World' iron block (2008)
4.15 stroke Eagle crank
4.310 (+.060")
10.25 to 1 Icon forged pistons
RPM rods
Edelbrock Hemi heads
.620 Comp roller cam & lifters
Barton 4150 single plane intake no carb
12qt Aluminum oil pan
Milodon oiling system
will run on pump gas
727 automatic trans
J convertor,
full manual valve body
deep trans pan
10.20's at 132mph in a 3000lb Barracuda
4 runs on fresh setup
$25,500 picked up in York,Pa 17408 (717) 577-0270
Re: For Sale - Race Parts - 1st Quarter [Re: fbs63] #3218336
03/05/24 02:34 PM
03/05/24 02:34 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Ptc 10" 727 converter.
Set up for BB with a big single,twin turbos or blower. Billet front half.
Steel stator High HP capable.
$700 obo. PM me here. Located in NW Indiana.
Re: For Sale - Race Parts - 1st Quarter [Re: fbs63] #3218539
03/06/24 10:14 AM
03/06/24 10:14 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Yukon gear YY C8.75-1350-F Pinion yoke.
29 spline forged u-bolt style 1350 joint. New in box.
$100. PM here. Located in NW Indiana. Will ship.
update [Re: fbs63] #3218889
03/07/24 04:48 PM
03/07/24 04:48 PM
ca
Swingin70 Offline
Swingin70  Offline
ca
update
K&R Pro Cube Delay Box [Re: Swingin70] #3218906
03/07/24 06:05 PM
03/07/24 06:05 PM
Indiana
Gabby63 Online content
Gabby63  Online Content
Indiana
I am selling my K&R Pro Cube Delay Box , in great condition , operates as it should , 325.00 - OBO -
Also if needed I have the 3D printed removable mount for 90.00 more .
Items are plus shipping .
Gary
Sold! [Re: Gabby63] #3219067
03/08/24 11:14 AM
03/08/24 11:14 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
CSU Gas Blow Through Dominator.
New, never had fuel in it. Dual needle and seat float bowls, dual boost referenced power valves, annular boosters. Perfect for pump or race gas set up.
Including billet E85 metering plates for conversion. Recommend sending to CSU for complete E85 conversion if desired. Have pics of internals if needed.
$1000 shipped Comparable carbs are $2500 now.
SOLD!
Holley 1 to 1 Linkage Kit - NEW [Re: moparts] #3219649
03/11/24 01:17 AM
03/11/24 01:17 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
New Holley 20-3 Throttle shaft kit conversion to 1 to 1 linkage ratio. Holley 4150 1-11/16" throttle plate.
Comes with primary and secondary shafts and plate screws. Open box.
Summit $83.35.
Sell for $50 shipped to continental US.
1974 VW Karman-Ghia
Sheetmetal Valve Covers SB Mopar [Re: moparts] #3219651
03/11/24 01:34 AM
03/11/24 01:34 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Unique brand fabricated aluminum valve covers for Small Block Mopar. Originally made in Iowa.
Early design with thin rails which were needed for W2 rocker and pushrod clearance.
Brushed finish with 1 hole per cover. Comes with long allen bolts.
These were about $275 when new, Sell for $90 + shipping
1974 VW Karman-Ghia
