Old fashioned Rev Kits #3212578
02/10/24 07:44 PM
02/10/24 07:44 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Auxiliary "valve" springs in the lifter valley, really they are lifter springs.
If you use these, do you use less spring on the valve ?
Re: Old fashioned Rev Kits [Re: hemienvy] #3212613
02/10/24 09:03 PM
02/10/24 09:03 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
They seem like such a sensible idea. But engine builders always tell me they are unnecessary, so I've never tried them.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Old fashioned Rev Kits [Re: hemienvy] #3212634
02/10/24 10:00 PM
02/10/24 10:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I always thought they would be a good idea to keep the roller wheel in constant contact with the lobe. But I could be way off base shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Old fashioned Rev Kits [Re: fourgearsavoy] #3212657
02/11/24 12:19 AM
02/11/24 12:19 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If you pitch a pushrod the lifter stays in its bore
Re: Old fashioned Rev Kits [Re: hemienvy] #3212658
02/11/24 12:30 AM
02/11/24 12:30 AM
AndyF Offline
AndyF  Offline
Not really. The valve spring controls the valve, and the rev kit keeps the lifter in contact with the lobe. Rev kits used to be standard on circle track engines but we see them less and less. We do have an engine going together now with a rev kit in it. They make sense to use but the correct lifters are hard to find. Isky used to make them for lots of different applications but a lot of those part numbers have been discontinued.
Re: Old fashioned Rev Kits [Re: AndyF] #3212664
02/11/24 02:16 AM
02/11/24 02:16 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
With the rev kit spring controlling the lifter, the valvespring no longer controls, or needs to control, the lifter, just the valve.
So why would you not use less valvespring ?
Re: Old fashioned Rev Kits [Re: hemienvy] #3212676
02/11/24 05:55 AM
02/11/24 05:55 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I have no personal experience with rev kits. But back in the day when Ford thought it was a better idea, I read an article on their philosophy. IIRC, the purpose of a rev kit is to increase the rpm limit of the engine, hence the name "rev" kit. Accomplishing this higher rpm limit with stiffer valve springs increased the stress on the entire valve train whereas the rev kit only increased the stresses on the cam/lifter. If you wanted to maintain your current rpm limit and installed a rev kit, I don't see why decreasing the valve spring would be a bad idea. But why? shruggy
Re: Old fashioned Rev Kits [Re: 6PakBee] #3212691
02/11/24 08:47 AM
02/11/24 08:47 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
My guess would be, no need to increase your RPM limit unless you also increased your cam to move the powerband up.
However, by keeping your same RPM limit, you could use less spring, which would tend to beat up parts less.
Re: Old fashioned Rev Kits [Re: hemienvy] #3212699
02/11/24 09:33 AM
02/11/24 09:33 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I had them on the old Max Wedge, Isky 550 Super LeGarrea,(?) in fact they helped real good, I could rotate the spring-retainer-valve with my fingers, lol, I had run them like that a few times (6800) before new ones. Amazingly no time difference with new ones. I added a bolt to center of holder since there’s no heat crossover in max heads (the springs made it bend up). It was all on there when I got engine.
Re: Old fashioned Rev Kits [Re: hemienvy] #3212715
02/11/24 10:49 AM
02/11/24 10:49 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I look to the 69 1/2 six pack engines as an example. Again, IIRC, the design rpm limit with the stock cam was about 5800 with the springs used. With the same cam timing events, the six pack engines have stiffer springs which raised the usable rpm limit to 6200.
Re: Old fashioned Rev Kits [Re: 6PakBee] #3212769
02/11/24 01:31 PM
02/11/24 01:31 PM
Canada
RobR Offline
RobR  Offline
Canada
Back in the M/P class days when 10000 to 12000 rpm was standard that was the only way to do it. Every M/P engine I ever saw had a rev-kit...
Re: Old fashioned Rev Kits [Re: RobR] #3213044
02/12/24 02:28 PM
02/12/24 02:28 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Given the work Ben Strader and others had to do to get the "Spinal Tap" LS to run at 11,000 rpm I wonder if the Modified Production engines from back in the day had any real valve control at those RPMs.
