Re: A body BB to Hemi MM
[Re: mopar dave]
#3212742
02/11/24 12:09 PM
02/11/24 12:09 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Dave, Hemi and wedge do not use the same mount. At least with factory blocks. I don't know if BME did something different or not?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: mopar dave]
#3212758
02/11/24 12:51 PM
02/11/24 12:51 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Do you know if BB and Hemi have the same block width? I dont see anything over on the Schumacher site. Same block, except Hemis have different motor mounts on them. Wedges have the ears, while Hemis have a little spot where 3 bolts thread in facing the skirt of the block on each side. The callies block I have has both the Wedge ears and the hemi pad on it, I think the BME blocks are the same way.
[Re: mopar dave]
#3212764
02/11/24 01:06 PM
02/11/24 01:06 PM
Posts: 12,253 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I put an aftermarket blocked Hemi in a 68 Dart. The outside dimensions of the new blocks will have differences from the originals. In the end, the ONLY way that I got it to fit was to buy an engine mount kit for the 'K', set the engine in and then tack the mounts together with everything in place. Then I removed the 'K', fully welded the mounts up and had it powder coated. Otherwise, a fraction of an inch or degree of measurement off anywhere meant it would not work. There is NO room for error.
Just my experience.
Master, again and still
[Re: mopar dave]
#3212766
02/11/24 01:13 PM
02/11/24 01:13 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I now know the master cylinder conversion block is not enough when using the Stage V covers. MC also has to be moved up about an inch or so. My buddy bought the new MC mount that moves it over further. I'll see if I can find that info again. It makes it a lot better.
2011 Drag Pak Challenger
[Re: mopar dave]
#3212804
02/11/24 04:35 PM
02/11/24 04:35 PM
rickseeman
Stuttgart, Arkansas
Yes, but it's pretty easy. I believe my buddy said you turn the bolt around and the rod goes on the other side of the brake pedal.
[Re: mopar dave]
#3212977
02/12/24 10:12 AM
02/12/24 10:12 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
As it was explained to me, the Original style shock tower mod was to just smash it in with a hammer. Modern builds usually have that area cut out and a fabricated piece welded in. Below is a link with a still-working picture of an original "clearanced" shock tower. Link
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3213051
02/12/24 03:18 PM
02/12/24 03:18 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Mine is in an E Body and not an A Body, but Indy does make a shock tower clearance passenger side rocker cover. This may or may not help in an A Body. I have never done it myself. I am able to remove the cover without any mods to the shock tower and in the factory mounting position even though front and mid plates are added. Hard to tell, but If you look closely there is a relief in the outside of the cover that does not interfere with any valve train internally.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3213139
02/12/24 09:30 PM
02/12/24 09:30 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I’m not that far from you if you wanted to look at mine.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
