Re: Tuff Wheel Adapters - Need A Lesson, Please
[Re: Remy-Z]
#3212459
02/10/24 12:44 PM
02/10/24 12:44 PM
Posts: 13,577 md
mopars4ever
md
3467186 Should be the part number. As far as i know the truck one should be the same depending on the year. https://www.oerparts.com/product/3467186.html Post some pics if you can. BTW, who restored the wheel? Have a pic of it? thanks
[Re: IMGTX]
#3212560
02/10/24 06:45 PM
02/10/24 06:45 PM
Posts: 1,833 Sault Ste. Marie, Ontario, Can...
moparmike1
A few questions:
1. Does your Charger Daytona have a tilt column?
2. Does your restored adaptor have a master spline?
3. Can you post pictures of your restored adaptor?
[Re: IMGTX]
#3212673
02/11/24 03:30 AM
02/11/24 03:30 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
That thick hooked wire holding the Horn contact disk to the adapter is the turn signal canceling mechanism. Aaaand the horn switch track retainer
[Re: Remy-Z]
#3213109
02/12/24 08:03 PM
02/12/24 08:03 PM
moparmike1
No, the Charger does not have a tilt column. The column going into the Charger is not a tilt column. You're losing me here. There's a column in the Charger that is not a tilt column, right? The column going into the Charger?? You're replacing the column currently in the car?
[Re: Remy-Z]
#3213122
02/12/24 08:32 PM
02/12/24 08:32 PM
moparmike1
Neither column has tilt. Yes, I am replacing the column. The car is being converted from a column-shift automatic to a manual transmission. I didn't want to have a column shifter left over after converting to floor shift. Ok, understood. The floor shift column, take a picture of the splined shaft where the Tuff wheel adaptor would bolt on. Does the splined shaft have a master spline?
