Re: Help with 4L60E (in a Mopar :)
[Re: Wirenut]
#3212187
02/09/24 01:00 PM
02/09/24 01:00 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Which TCM/computer are you using?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3212211
02/09/24 02:26 PM
02/09/24 02:26 PM
Posts: 630 Ct
Wirenut
Ct
Which TCM/computer are you using? I don’t know it’s a standalone. Also early on they sent a replacement . All of the electrical functions tested ok
[Re: Moparite]
#3212481
02/10/24 01:49 PM
02/10/24 01:49 PM
jbc426
West Coast, USA
Does that trans have kick down or TV throttle valve cable linkage? On an operational note, the 4L60e's are computer controlled and don't use a vacuum module or a throttle valve cable to kick down like the 700R or 2004R's do.
[Re: Wirenut]
#3212486
02/10/24 02:04 PM
02/10/24 02:04 PM
jbc426
West Coast, USA
It is either a computer controller issue of a problem inside the transmission itself. If i was facing this, I would change the fluid and filter, and then swap in an aftermarket stand-alone controller in. They are not cheap, but you get what you pay for. Here's one example. https://www.usshift.com/usq4.shtmlIf there are still problems with the shifting, you may want to have your transmission rebuilt by a quality transmission shop who specializes in 4L60's or just buy another transmission outright. Trying to order and swap in a valve body in the car may help, but it may not either. Such is the nature of our hobby.
[Re: jbc426]
#3212512
02/10/24 03:49 PM
02/10/24 03:49 PM
Posts: 630 Ct
Wirenut
Ct
Does that trans have kick down or TV throttle valve cable linkage? On an operational note, the 4L60e's are computer controlled and don't use a vacuum module or a throttle valve cable to kick down like the 700R or 2004R's do. Correct. It has a tps
[Re: jbc426]
#3212513
02/10/24 03:54 PM
02/10/24 03:54 PM
Posts: 630 Ct
Wirenut
Ct
It is either a computer controller issue of a problem inside the transmission itself. If i was facing this, I would change the fluid and filter, and then swap in an aftermarket stand-alone controller in. They are not cheap, but you get what you pay for. Here's one example. https://www.usshift.com/usq4.shtmlIf there are still problems with the shifting, you may want to have your transmission rebuilt by a quality transmission shop who specializes in 4L60's or just buy another transmission outright. Trying to order and swap in a valve body in the car may help, but it may not either. Such is the nature of our hobby. Thanks for the reply . The controller was replaced . I was able to test the function while driving the car . Rigged up a couple of volt meters at the transmission harness plug and watched them going down the road . The problem is in the tranny . Just wasn’t sure if there was something else other than the valve body to consider. I’ve talked to a couple of shops , they just say replace the valve Body .
[Re: Wirenut]
#3212540
02/10/24 05:41 PM
02/10/24 05:41 PM
jbc426
West Coast, USA
You can check out this link to find both upgraded hard parts, shift kits and technical info on setting up and improving the 4L60. With 50k miles on it, it might be prudent to freshen the entire transmission if you are going to be in there. https://www.sonnax.com/gm_4l60e
[Re: volaredon]
#3212645
02/10/24 10:44 PM
02/10/24 10:44 PM
Posts: 601 Mass
charge70
Mass
Could be a wiring problem from the trans connector to the solenoids or speed sensors.Are you able to rig something up to get codes?
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#3212851
02/11/24 07:09 PM
02/11/24 07:09 PM
Posts: 630 Ct
Wirenut
Ct
Could be a wiring problem from the trans connector to the solenoids or speed sensors.Are you able to rig something up to get codes? I have wondered that, but wouldn’t it affect it otherwise? Meaning in drive or overdrive it works perfectly. No I don’t think it’s that smart . It just has a stand alone controller .
[Re: Wirenut]
#3213002
02/12/24 12:17 PM
02/12/24 12:17 PM
jbc426
West Coast, USA
Could be a wiring problem from the trans connector to the solenoids or speed sensors.Are you able to rig something up to get codes? I have wondered that, but wouldn’t it affect it otherwise? Meaning in drive or overdrive it works perfectly. No I don’t think it’s that smart . It just has a stand alone controller . I wouldn't trust their computer even though you replaced it once. I get it that changing to a different TCM is an expensive part to throw at the problem. 4L60's have their own inherent weaknesses, but they can be overcome with aftermarket parts including that goofy 3.06 to 1 first gear ratio.
[Re: Wirenut]
#3215658
02/23/24 06:32 PM
02/23/24 06:32 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I can't for the life of me understand why on earth someone would choose THAT transmission to retrofit into ANYTHING! They are one of the worst transmissions ever, I run a mopar specialty shop and still end up replacing more 4l60E transmissions than all others COMBINED!
[Re: HotRodDave]
#3215665
02/23/24 06:51 PM
02/23/24 06:51 PM
Posts: 2,237 ILLINOIS
volaredon
ILLINOIS
I can't for the life of me understand why on earth someone would choose THAT transmission to retrofit into ANYTHING! They are one of the worst transmissions ever, I run a mopar specialty shop and still end up replacing more 4l60E transmissions than all others COMBINED! Pretty much what I was thinkin
[Re: volaredon]
#3215772
02/24/24 10:36 AM
02/24/24 10:36 AM
jbc426
West Coast, USA
I can't for the life of me understand why on earth someone would choose THAT transmission to retrofit into ANYTHING! They are one of the worst transmissions ever, I run a mopar specialty shop and still end up replacing more 4l60E transmissions than all others COMBINED! Pretty much what I was thinkin I'm curious to hear your input regarding a list of the main points of failure in the 4L60's that have met their demise in your shop? Is it generally just burned up clutches and bands or are the failures randomly spread throughout the transmission guts? Thanks in advance.
[Re: jbc426]
#3218511
03/06/24 01:41 AM
03/06/24 01:41 AM
HotRodDave
Kalispell Mt.
Solinoids, sensors, the sun shell breaks (we upgrade em all to "the beast"), clutches burn up mostly 4th gear but all of em are suceptible, the valve body spacer plate wears out so the check balls don't completly seal off and sometimes they get stuck in the plate or blow all the way thru.
[Re: HotRodDave]
#3218577
03/06/24 01:15 PM
03/06/24 01:15 PM
jbc426
West Coast, USA
Solinoids, sensors, the sun shell breaks (we upgrade em all to "the beast"), clutches burn up mostly 4th gear but all of em are suceptible, the valve body spacer plate wears out so the check balls don't completly seal off and sometimes they get stuck in the plate or blow all the way thru. Thanks for the info.
[Re: volaredon]
#3218605
03/06/24 02:54 PM
03/06/24 02:54 PM
Posts: 630 Ct
Wirenut
Ct
I can't for the life of me understand why on earth someone would choose THAT transmission to retrofit into ANYTHING! They are one of the worst transmissions ever, I run a mopar specialty shop and still end up replacing more 4l60E transmissions than all others COMBINED! Pretty much what I was thinkin This is a response I would have expected from the facebook crowd. Responses here are typically intelligent and thoughtful. Yours is neither. Never once in my post did I ask for an opinion on the quality of the transmission. In the future if you don’t have anything constructive, just keep scrolling. Or head over to Facebook. You’ll fit right in .
