Ideal build for a reliable 1200 plus hp in a street car?
#3211623
02/07/24 06:46 PM
02/07/24 06:46 PM
Posts: 4,681 Wichita
GY3
Wichita
How would you do it?
I see all these guys running stout times at drag and drive events and it kills me!
2nd or 3rd gen Hemi?
RB?
Which power adder?
Re: Ideal build for a reliable 1200 plus hp in a street car?
[Re: dvw]
#3211678
02/07/24 09:08 PM
02/07/24 09:08 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
I don't know enough about G3 Hemis, if they can make 1200 boosted with stock block and heads, that would be really hard to beat.
Turbos and E85 at a minimum on a moderate sized RB would be my route, but I'm a big block person. The G2 hemi chambers are better for boost than wedges but also have heavier valvetrains and would be harder to package a turbo kit if you're trying to keep inner fenders. I don't see many huge CI twin turbo setups, it seems 540-555 is pretty common, with 572 being the upper limit. At "only" 1200 hp I'd think you could easily get it done under 500". You also wouldn't need the best of the best for cylinder heads either. I know of a couple 440-1 headed turbo big blocks that make 1200+.
One thing I have seen interesting is the higher horsepower turbo BBC stuff sounds like they actually move to our Chrysler wrist pin and rod journal size for additional load capability.
Bigger concern is I don't think a 727 is going to live at 1200 hp behind anything long term, so a turbo 400 would be in the cards too.
[Re: Blusmbl]
#3211774
02/07/24 10:47 PM
02/07/24 10:47 PM
Posts: 4,682 On the parachute mount
n20mstr
Not cheap for drag and drive
It will take decent money, especially to go fast
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3211784
02/07/24 11:15 PM
02/07/24 11:15 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Build an 800hp big block with a fogger and EFI. I'd spring for steel, paired shaft rockers and G Force GF5R or something similar. If that guy in the GTO can make it all of the way from Canada....
Another option would be a couple of turbos on a 650-700hp long block and stay under 15psi.
From a maintenance perspective I could see where a person would be time/money ahead using a wedge platform instead of the more complicated hemi valvetrain/intake manifold designs.
If I were going this direction I'd do a 540 Cube Indy 573-13 deal with steel rockers, Ti valves and a Holley Dominator EFI with CnP.
[Re: GY3]
#3211862
02/08/24 09:51 AM
02/08/24 09:51 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
Mine fits this category for the most part, but I think nitrous is too much work for a drag and drive event. My combo on E85 w/ a roots blower would be my choice. The E85 might be a pain to find along the way, but you'd need it to cool everything. Here's MY reasoning behind that....... Nitrous is too much work, even though I love it. Turbos are too much plumbing and I'd have to cut the car up somewhat to fit everything. A procharger would be cool, but again, packaging looks like it' be a real pain and I refuse to cut my car up at all. My car is a G2 hemi which is why the packaging is an issue. G3 or whatever would be easier.
[Re: an8sec70cuda]
#3211877
02/08/24 10:16 AM
02/08/24 10:16 AM
Posts: 75,021 U.S.S.A.
JohnRR
U.S.S.A.
Mine fits this category for the most part, but I think nitrous is too much work for a drag and drive event. My combo on E85 w/ a roots blower would be my choice. The E85 might be a pain to find along the way, but you'd need it to cool everything. Here's MY reasoning behind that....... Nitrous is too much work, even though I love it. Turbos are too much plumbing and I'd have to cut the car up somewhat to fit everything. A procharger would be cool, but again, packaging looks like it' be a real pain and I refuse to cut my car up at all. My car is a G2 hemi which is why the packaging is an issue. G3 or whatever would be easier. Racers like Morris , Bailey and Mitchell/Cleetus are running duel fuel systems, gas on the street and methanol at the track. That would be one way to get around the fuel availability issue, but does add complexity to the total system. All it takes is $$$$$
[Re: mopar dave]
#3211980
02/08/24 02:17 PM
02/08/24 02:17 PM
Posts: 696 AZ
d4rt
AZ
Check out Steve Morris Racing. The guy specializes in big HP. I just watched one of his vids, 400ci SB 1200hp. I have seen some of his BB make 4500+HP. He seems to be the man for big street HP Too. Makes me want to by a Chevy. He had another vid with a mild 505 that made an easy 1200+HP. Check him out, he has a bunch of vids. He has a video up on YouTube of a 1600 hp G3 build from about 5 months ago too: https://www.youtube.com/watch?v=c8Vu0r8uGi0Based on the video sounds like it's a BGE 392 with stock heads and twin 67mm turbos. It made 1157 on 93 pump and 8 lbs of boost and 1600 on E85 and 17 lbs of boost. Doesn't seem like they pushed the tune on E85 either.
[Re: d4rt]
#3211994
02/08/24 02:58 PM
02/08/24 02:58 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not a turbo guy……. But for a 1200hp drag n drive combo, that really seems like the way to go.
[Re: fast68plymouth]
#3212075
02/08/24 08:18 PM
02/08/24 08:18 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I’m not a turbo guy……. But for a 1200hp drag n drive combo, that really seems like the way to go. I got converted to liking turbos when i bought an F150 with a 3.5l twin turbo. I traded it for a similar 2021, chipped it, and it makes 500 hp on pump 93/e85 mix. Not bad for a little 213cubic inch v6!
