Mopar Differential For Sale - 1st Quarter #3202020
01/03/24 08:12 PM
01/03/24 08:12 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3202811
01/06/24 05:56 PM
01/06/24 05:56 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
8 3/4 center section-489 case with spool. I broke the gears after about 750 runs. Would need new ring and pinion and to be set up. Unit is complete-have a small yoke to go with it. Asking $275. Can't ship. Contact Bud: Kramden426 at aol.com
489case spool.JPG (953 downloads)
489case spool2.JPG (951 downloads)
8 3/4 Housings Narrowed to 48" Mini Tub A Body [Re: budman1965] #3205176
01/16/24 10:19 AM
01/16/24 10:19 AM
blewbyu Offline
blewbyu  Offline
I have 2 housings 8 3/4 narrowed to 48" and perches at 36" Big bolt pattern axles with green brgs and 10" X 2 1/2" brake backing plates. If your gonna mini tub an a body this are made to fit under the frame rails. $850.00 each plus shipping from Florida
If interested can get you better photos. blewbyu2bad@aol.com
narrow 834.jpeg (821 downloads)
Dana 60 Narrowed for Mini Tubs on A Body [Re: blewbyu] #3205180
01/16/24 10:22 AM
01/16/24 10:22 AM
blewbyu Offline
blewbyu  Offline
I have a Dana 60 narrowed for mini tubs 48" end to end and 36" pads for under frame rails, 35 spline large axles with green brgs with spool and 4.10 gears and no brakes. Has been sitting in my shop for some time all new. $1800.00 plus shipping from Florida. For another $400 I can include a 35 spline Detroit Locker blewbyu2bad@aol.com
dana 1.jpeg (819 downloads)
dana 2.jpeg (819 downloads)
dana 3.jpeg (820 downloads)
dana 4.jpeg (821 downloads)
Assorted 8 3/4 housings [Re: blewbyu] #3205182
01/16/24 10:29 AM
01/16/24 10:29 AM
blewbyu Offline
blewbyu  Offline
I have the following housings with axles no backing plates $200.00 each plus shipping from Florida
1 - E body
2 - 68-70 B body
1 - 71-72 B Body
2 - Truck Housings
axles 1.jpeg (818 downloads)
A Body 8 3/4 rear complete SBP [Re: blewbyu] #3205186
01/16/24 10:40 AM
01/16/24 10:40 AM
blewbyu Offline
blewbyu  Offline
I have two A Body small bolt pattern eight and three-quarter rear ends complete drum the drum no center chunks. Really clean housings
$1000.00 Plus shipping from Florida. Blewbyu2bad@aol.com
834 a.jpeg (815 downloads)
834 a1.jpeg (817 downloads)
834 a2.jpeg (815 downloads)
834 a3.jpeg (815 downloads)
8 3/4 & Dana 60 Axle Bearing Retainer Adjuster Flanges [Re: moparts] #3206723
01/21/24 02:37 AM
01/21/24 02:37 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
8 3/4 & Dana 60 Axle Bearing Retainer Adjuster Flanges. Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
E-body 8 3/4 posi…4.30 gears [Re: Memongo] #3210499
02/04/24 03:21 PM
02/04/24 03:21 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
E- body 8 3/4
4.30 gears in 489 case in good shape-posi
Disassembled from Axle housing, but housing, axles and 11” backing plates all available. No drums
Will sell as a complete set, or pieces.
Pictures available on request.
Housing is from a 1970 Challenger
Thanks for the ad
Center section with gears- $500
Axle housing-$150
11” backing plates- $150
PM me here
Delivery available to Indy Swap Meet on March 1 available.
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3215424
02/22/24 04:41 PM
02/22/24 04:41 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Original 3.23, 4.10 and 3.54 gear ratio and "use limited slip lube" rear end tags. The 3.54 tag is a little rough but still usable. $20 + postage for all four. No Paypal.
gt340 at yahoo.com
Gear tags.JPG (429 downloads)
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3216243
02/26/24 02:20 AM
02/26/24 02:20 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Mopar A-Body Dana 60 For Sale
• Stock width
• Dr. Diff lightweight spool
• Dr. Diff 35 spline axles with green bearings
• 4.10 Motive ring and pinion
• Forged 1350 super duty bolt through yoke
• Heavy duty boxed in and fully welded perches
• Axle tubes welded to carrier
• LPW Ultimate-60 cover with main cap jack screws
• 3” screw in wheel studs
• All new internals
$2,000. Shipping available. Message me on Moparts. Thanks.
Re: Mopar Differential For Sale - 1st Quarter [Re: moparts] #3217039
02/29/24 01:37 PM
02/29/24 01:37 PM
Indiana
Max Wedge Wagon Offline
Indiana
For Sale:
Dana 60 Car Rear End - 55" from Flange to Flange - Moser axles 35 Spline - no Center Section - $500
Call Bill @ 765-437-8393
Kokomo, IN
Call Bill Home 765-457-0132 Cell 765-437-8393
Re: Mopar Differential For Sale - 1st Quarter [Re: Max Wedge Wagon] #3217927
03/04/24 08:39 AM
03/04/24 08:39 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Yukon gear forged 1350 yoke.
YY C8.75-1350-F pinion yoke. New in box. 29 spline. U-bolt style. Used on 8.75 with 29 spline pinion gear.
$100 plus shipping. PM me here. Located in NW Indiana.
