...removing center divider on a dual plane intake #3210216
02/03/24 10:54 AM
02/03/24 10:54 AM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
so '02 Magnum 360, stock heads, Comp #20-745-9 (212-218 (264/270), .480/.480, on a 114* LSA - a truck cam, and a 2300 2bbl Sniper. My Sniper sits on a 2bbl adapter atop my Eddy 7577 dual plane. The adapter has a contoured bottom to allow the flow to 'expand', but there is the immediate wall of the 4bbl right below it, and after lots of reading I'm thinking I should remove about an inch or more of the 4bbl center divider, maybe leaving a half inch remaining, and radiusing the upper edge.
This is a 'truck' application - my Mag 360 is essentially 'done' by 4500 rpm, and from what I'm reading there don't seem to be any real drawbacks, and potentially a couple pros. What I dislike the most is the 'gap' between the adapter and the intake - it just looks...'improper'. I have the intake off to replace the original lifters (with a fresh set of Viper V10 units from Top Line), and while it seems to run fine I'm just wondering about cleaning things up a little while it's open. Thoughts?
as-is configuration -
seems like a less-than-awesome setup -
intake as-is -
intent is to remove the divider as shown...
...to result in this -
...and what's interesting is the big block dual plane I had before had a 'reduced' divider from the factory -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210241
02/03/24 12:17 PM
02/03/24 12:17 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
sawzall since the intake is off already... but that's just me
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: ...removing center divider on a dual plane intake [Re: Brad_Haak] #3210242
02/03/24 12:25 PM
02/03/24 12:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’ll just say that I ported a couple that were cut out and welded back in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210260
02/03/24 01:51 PM
02/03/24 01:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The ONLY real way to know is to test.....test......test.
Or read about it from someone else who tested it on a combo as similar to yours as possible.
Master, again and still
Re: ...removing center divider on a dual plane intake [Re: DaveRS23] #3210263
02/03/24 02:19 PM
02/03/24 02:19 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
well I can't test, and I was just surfing for some real-world feedback. Some other threads had indicated non-negative results, and I was just bumping the topic for any new revelations.
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210277
02/03/24 02:38 PM
02/03/24 02:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think there was an article in Mopar Action a while back - late last year ? - that dealt with modifying that truck intake.
Re: ...removing center divider on a dual plane intake [Re: topside] #3210303
02/03/24 04:41 PM
02/03/24 04:41 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
the question really is...'open it all up' or 'isolate the two sides' - I can use the open scenario described above (which I kinda-sorta already have), or, I can opt for an adapter like this and completely isolate the two halves of the throttle body to the two sides of the intake -
Hell I dunno... 🤯
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210314
02/03/24 05:43 PM
02/03/24 05:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Cutting the center divider almost always improves power a little in the higher RPM ranges, on dual plane intakes in my experience.
But you said your engine is done by 4500 rpm, so it would be a toss-up in my opinion.
Re: ...removing center divider on a dual plane intake [Re: jwb123] #3210315
02/03/24 05:50 PM
02/03/24 05:50 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
agreed - there's likely power to be gained in the upper rpms, and the question tho is are there drawbacks on the low end by removing the divider - that's the big question, and that lends to fully isolated, or open, and pros and cons of each way. It may be 'unanswerable' without a dyno, and I'm not going to that level of effort.
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210325
02/03/24 06:51 PM
02/03/24 06:51 PM
PA.
"Little"John
"Little"John
PA.
For sure I wouldn’t trust a dyno for this test.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: ...removing center divider on a dual plane intake [Re: pittsburghracer] #3210330
02/03/24 07:23 PM
02/03/24 07:23 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
yah my main thoughts are on how much better (if any) the MAP sensor might function if the divider were trimmed down and there was a bit more(?) signal strength on it from 'all '8 vs a 'limited 8' - that's a question I'll have to ask Holley on Monday. I think tho that what I am also seeing is that fully isolating the two halves is not the best idea...
Re: ...removing center divider on a dual plane intake [Re: Mad-Max] #3210355
02/03/24 09:25 PM
02/03/24 09:25 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I've done many a dual plane 4bbl intake and cut the center to varying depths. Depth makes a big difference on HP/TQ. I now just add different thickness intake spacers. Works better and the intake is better for resale intact. So what you have with that 4/2 plate is a spacer. Add a 1/2" and see how it feels when driving uphill with a load.
Re: ...removing center divider on a dual plane intake [Re: A/MP] #3210829
02/05/24 01:51 PM
02/05/24 01:51 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
...I had a good conversation with Holley Tech, and they have no problem with my current setup - apparently the gap between the adapter and intake is...for lack of a better term...a non-issue, and recommends to run it as-is. I would love to get the true 2-hole adapter and run it to see if there were any perceivable difference, but for my application it doesn't sound like there is anything to gain by that, so, unless y'all see something 'off' in the config or datalog I'll (continue to) run it as-is. The good news is by all accounts milling the divider would not benefit my low-rpm 'truck' application at all, and could actually induce low-rpm drivability issues, so I can forget about intake mods and just bolt it up. If, down the trail, I want to drop on a 2-hole adapter I can do that...but that'll be way down the trail.
Thanks all
- Sam
