Shock adjustment help needed, launch video #3209388
01/30/24 11:59 PM
01/30/24 11:59 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Here's a video of my coupe launching. I have double adjustable afco shocks on all four corners. It is a manual transmission. Bias ply DOT slicks. Based on the video, what can I do with the shocks?
https://www.instagram.com/reel/C2tOMNaObib/
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209410
01/31/24 06:08 AM
01/31/24 06:08 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
If the vid is posted on You Tube, there is an option to slow the video down to 1/4 speed. I couldn't seem to find that option on the above clip.
Re: Shock adjustment help needed, launch video [Re: Tig] #3209415
01/31/24 07:54 AM
01/31/24 07:54 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Send this video to Jeff McConnel who rides with Doc McEntire. He knows his stuff.
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209416
01/31/24 08:02 AM
01/31/24 08:02 AM
gregsdart Offline
gregsdart  Offline
Joel, from what i can see, i think the rear axle is extending extremely fast, hitting the end of the shock travel, rebounding and repeating all in about 5 to seven feet.
If you can stiffen extension, i would be tempted to go extremely stiff, maybe starting as tight as possible. Also i would drop the launch rpm if you can some. If your suspension has a high and short instant center, that might be part of the problem.
Re: Shock adjustment help needed, launch video [Re: gregsdart] #3209417
01/31/24 08:49 AM
01/31/24 08:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Like stated if you put the video on You Tube it can be slowed down and stopped at spots for a more in depth look. I agree on tightening the rear. Both rebound and compression. The front has very little travel but tighten up the rebound there as well. Once the bounce is corrected it needs some wheel speed. Not being a stick guy my thought is raising the rpm at the start will allow that adjustment..
Doug
Re: Shock adjustment help needed, launch video [Re: dvw] #3209478
01/31/24 01:09 PM
01/31/24 01:09 PM
Minnesota
Minnesota
I'll try and get the video on to YouTube. Super busy in the throws of sick week. Maybe tonight will be able to get it up there.
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209485
01/31/24 01:16 PM
01/31/24 01:16 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Tightewn the extension to start on the rear....What is the rest of the rear suspension?
Re: Shock adjustment help needed, launch video [Re: Al_Alguire] #3209526
01/31/24 03:04 PM
01/31/24 03:04 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Id consider freeing up the extension on the Front as well suggestion previously made on the rear...Let it get a little pitch momentum. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Shock adjustment help needed, launch video [Re: W.I.N. Racing] #3209551
01/31/24 04:03 PM
01/31/24 04:03 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Should be able to play this at .25x speed
Re: Shock adjustment help needed, launch video [Re: Blusmbl] #3209560
01/31/24 04:35 PM
01/31/24 04:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m def not a chassis guy, but it seems to me that fundamentally it’s going to be hard to keep the suspension loaded properly when it sounds like there is an “almost” bog after you leave.
In my mind I’m thinking there is some relaxing of the suspension when that happens.
Re: Shock adjustment help needed, launch video [Re: Al_Alguire] #3209567
01/31/24 04:40 PM
01/31/24 04:40 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The car has a 4 link rear.
I run my rear shocks on the Road Runner, at full stiff on both Extension, and rebound. The more RPM, and harder I hit the tire, the faster it goes.
69 GTX 68 Road Runner
Re: Shock adjustment help needed, launch video [Re: JERICOGTX] #3209659
01/31/24 09:39 PM
01/31/24 09:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Now that I can watch in slow motion. The rear looks to have no seperation (even squats a tad) but still appears to dead hook until it bounces. Also no wheel speed. My first thoughts woukd be it needs more rpm and less tire pressure to gain wheel speed. But the underlying problem may be a bog leading to the above issues. Not sure I'd worry much about the front until the rear is fixed.
Doug
Re: Shock adjustment help needed, launch video [Re: dvw] #3209674
01/31/24 10:52 PM
01/31/24 10:52 PM
Minnesota
Minnesota
Thanks for all the input. So if it has no separation would tightening the extension help it or hurt it? As far as the bog, there's nothing I can do about that for tomorrow's race. So I'll just have to live with that.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209690
02/01/24 12:17 AM
02/01/24 12:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would say yes as it may reduce the bounce back after the hit. It may like a looser comp setting to aloow it to squat. That might give it some wheel speed. It's possible the 4 link is way off as well.
Doug
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209696
02/01/24 12:57 AM
02/01/24 12:57 AM
Try stiffening all four up as stiff as you can them and the see what that does and go from their wrench scope
It may only need the rear only stiffer, tighter, but I would do both and then if that helps start softening the fronts a little bit at a time until you like it one way or the otherwrench scope up twocents
Re: Shock adjustment help needed, launch video [Re: Blusmbl] #3209707
02/01/24 08:15 AM
02/01/24 08:15 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Very little suspension change front or rear in that video, everything looks way too stiff but then again I'm a Caltrac guy. How much travel does it have front and rear ? are you topping stuff out or reaching the limits of the suspension ? I know it sucks to have to use a race meeting for test and tune but I'd go looser on ext front and rear and see how the car reacts.
Re: Shock adjustment help needed, launch video [Re: Tig] #3209717
02/01/24 09:59 AM
02/01/24 09:59 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
One thing to consider is these tracks are super tight from what I have seen this week. I think that is one reason Lutz in his pro mod has had a hard time getting down and is 2nd overall to a Coyote Powered mustang on a drag radial(6.29!) Some of the stick cars are running radials now as well.
Joel you might need to loosen the clutch up some to get the bog out, the wheel speed might be hard to come by with the tight tracks. A torque converter would also be a good solution and it would get that pesky stick out of the way eek grin
68 Barracuda Formula S 340
Re: Shock adjustment help needed, launch video [Re: Bad340fish] #3209753
02/01/24 12:18 PM
02/01/24 12:18 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
This is why no one will remember your name Claude...
Re: Shock adjustment help needed, launch video [Re: Hemi_Joel] #3209755
02/01/24 12:24 PM
02/01/24 12:24 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I would agree stiffen the extension. Not suspension but what weight flywheel do you have? Many years ago 1980's I raced an Anglia with a four link, four speed, and it weighed 2,200 lbs with me in it. Ran low 10's high 9's Had a 30 lb flywheel in it, put a 15 lb wheel in it and it was so much easier to launch and drive. Light car does not need all the torque multiplication of a heavy flywheel.
Re: Shock adjustment help needed, launch video [Re: JERICOGTX] #3209764
02/01/24 01:34 PM
02/01/24 01:34 PM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Savage reply. LOL.
