Remove Bell-housing or not
#3209556
01/31/24 04:24 PM
01/31/24 04:24 PM
Posts: 4,858 Star Idaho
67vertman
Star Idaho
When you replace a clutch on and A B C or E-body, do you remove the bell-housing or leave it? And Why.
My Monster are real!
Living within your means makes life pretty easy.
Re: Remove Bell-housing or not
[Re: 67vertman]
#3209561
01/31/24 04:36 PM
01/31/24 04:36 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Remove it ... WHY ??? try it without doing so and report back ...
[Re: stumpy]
#3209568
01/31/24 04:41 PM
01/31/24 04:41 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
The only one I know you have to remove the clutch/flywheel first is the big truck bellhousing on a Slant. Some of the bolts are behind the flywheel.
[Re: JohnRR]
#3209574
01/31/24 04:54 PM
01/31/24 04:54 PM
67vertman
Star Idaho
Remove it ... WHY ??? try it without doing so and report back ... I have done it, and yes it take a little more time but not impossible. The worst part for me is aligning the throw-out bearing.
[Re: slantzilla]
#3209575
01/31/24 04:55 PM
01/31/24 04:55 PM
67vertman
Star Idaho
The only one I know you have to remove the clutch/flywheel first is the big truck bellhousing on a Slant. Some of the bolts are behind the flywheel. Good to know.
[Re: stumpy]
#3209576
01/31/24 04:57 PM
01/31/24 04:57 PM
67vertman
Star Idaho
Remove because it's in the way of everything you need to replace and it only takes a couple minutes extra which you would spend working around it anyway. Can you even get the pressure plate out with it on? Yes, drop out the clutch disk first.
[Re: JohnRR]
#3209774
02/01/24 02:09 PM
02/01/24 02:09 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Remove it ... WHY ??? try it without doing so and report back ... Reporting...I've done it many (most) times. PP and disc comes out the bottom easily. Only hassle is having to deal with the PP bolts two at a time. Even the FSM says so.
[Re: John_Kunkel]
#3209967
02/02/24 11:31 AM
02/02/24 11:31 AM
JohnRR
Remove it ... WHY ??? try it without doing so and report back ... Reporting...I've done it many (most) times. PP and disc comes out the bottom easily. Only hassle is having to deal with the PP bolts two at a time. Even the FSM says so. I've done it too ,but if the trans is out and I'm not doing it in between rounds at the track what's the point? The OP has done it and knows that it is doable so I'm curious as to the reason for the question? The FSM is geared toward the guy that getting paid an hour to do a 3 hour job , usually the bellhousing is filled with a sludgy coating and I find it easier to clean it out with the bellhousing in the parts washer .
[Re: JohnRR]
#3209980
02/02/24 12:20 PM
02/02/24 12:20 PM
Posts: 10,775 North Dakota
6PakBee
North Dakota
I wondered the same thing.
[Re: JohnRR]
#3209999
02/02/24 01:02 PM
02/02/24 01:02 PM
John_Kunkel
Rio Linda, CA
Remove it ... WHY ??? try it without doing so and report back ... Reporting...I've done it many (most) times. PP and disc comes out the bottom easily. Only hassle is having to deal with the PP bolts two at a time. Even the FSM says so. I've done it too ,but if the trans is out and I'm not doing it in between rounds at the track what's the point? The point is not having to deal with the starter and Z-bar. Sure, if the inside of the bell needs cleaning or the flywheel needs resurfacing, remove the bell... but for a simple clutch replacement why remove the bell?
[Re: JohnRR]
#3210095
02/02/24 05:23 PM
02/02/24 05:23 PM
67vertman
Star Idaho
Remove it ... WHY ??? try it without doing so and report back ... Reporting...I've done it many (most) times. PP and disc comes out the bottom easily. Only hassle is having to deal with the PP bolts two at a time. Even the FSM says so. I've done it too ,but if the trans is out and I'm not doing it in between rounds at the track what's the point? The OP has done it and knows that it is doable so I'm curious as to the reason for the question? The FSM is geared toward the guy that getting paid an hour to do a 3 hour job , usually the bellhousing is filled with a sludgy coating and I find it easier to clean it out with the bellhousing in the parts washer . Only when swapping out the clutch. I am getting ready to do a total trans replacement, 4sp to 5sp and was just thinking about it so I throw it out there as a topic starter.. This one will be a full bellhousing removal as I may resurface the fly wheel if needed.
[Re: 6PakBee]
#3210096
02/02/24 05:25 PM
02/02/24 05:25 PM
67vertman
Star Idaho
I wondered the same thing. Just for a topic starter.
[Re: 67vertman]
#3210217
02/03/24 10:58 AM
02/03/24 10:58 AM
6PakBee
North Dakota
I wondered the same thing. Just for a topic starter. Not a problem, question asked, question answered.
